Help with tach wire
Thanks for the link , but it's kind of confusing. I will search for the C-100 connector tomorrow morning
Under-hood it looks like this:
[IMG]
[/IMG]Inside the car:
[IMG]
[/IMG]This is '96
[IMG]
[IMG]
[/IMG]This is '96
Thanks a lot that really helps. Where do you get those diagrams from ?
In the diagram the tach is the white wire (#E1). You see the location on the right side of the diagram, right next to the letter "E".
This view is on the motor side of the connector, so under the dash it will be on the LEFT side of C-100; the WHITE wire.
Like the man said...You really need an FSM!
I used a Raptor shift light, mounted behind the AC grill. I used a coat hanger wire to fische the Raptor wires down to the C100 connector, being sure to disconnect the battery first, and staying the hell away from that yellow wire running to the steering wheel (air bag circuit).
This is where the Raptor fits quite nicely with installation amounting to drilling a hole and taping the barrel of the light.
There is a good ground spot on the hood release bracket, if I recall, and I believe A1 (bottom right on the diagram) is a switch-on power source for your light.
P.
P.
I didn't see what year Vette the OP has. I have an FSM for the 1990 L98 and ZR-1. I double checked to see I was looking at the L98 schematic, and it clearly shows in at least two diagrams - a schematic and the connector pin-out - that the tach wire is E1. Hummmm.... What MY are we actually looking for, might be a good question, huh?
P.
P.
*** I checked and it looks like he's got a '94. Here's his first request:
http://forums.corvetteforum.com/1584666510-post1.html
P.
, thanks a lot and yes I need a FSM
cuz I do most of the work by myself. I have the same shiftlight from raptor *** I checked and it looks like he's got a '94. Here's his first request:
Yes , it's a '94.
It's a '94 and will be updating the thread
Kiddin of course
