need a switch
Old Apr 29, 2014 | 08:09 PM
Jig A Low's Avatar
Jig A Low
Default need a switch
Hey guys,
I've been having some issues with the wipers on my '85 and would like to replace the switch, problem is I'm having trouble finding one. does anyone have a source for this switch?
thanks
Old Apr 29, 2014 | 08:59 PM
HlhnEast's Avatar
HlhnEast
I dont know what issues you are having but you can take the switch apart, clean and lube it for better operation. I did this to my '85 and it works much better. A lot of wiper issues are actually generated by the printed circuit board in the motor itself. This board is made of unobtanium and you must take your chances with used ones from a recycler like vette2vette
Good luck!
Old Apr 29, 2014 | 10:20 PM
gerardvg's Avatar
gerardvg
Below is the wiper motor cover with circuit board that is not made with unobtainable.
http://www.parts123.com/parts123/yb....5Z50000050F~~~
Here are some second hand wiper motor switches.
http://www.ebay.com/itm/1984-1989-Corvette-C4-Windshield-Wiper-Switch-ORIGINAL-GM-/390743592979?pt=Motors_Car_Truck_Parts_Accessories&hash=item5afa221013&vxp=mtr
http://www.ebay.com/itm/1984-1989-Corvette-Windshield-Wiper-Switch-ORIGINAL-GM-/390831395572?pt=Motors_Car_Truck_Parts_Accessories&hash=item5aff5dd2f4&vxp=mtr
Old Apr 30, 2014 | 07:00 AM
Jig A Low's Avatar
Jig A Low
thanks guys,
I've just started having operational issues with the wipers, some times they work like they should, other times they will stop in mid-swipe, then at times they won't go into "park" mode. sometimes just working the switch back and forth they will be ok, other times not so much. the weird thing is that they ALWAYS work if you put them in "high" vs. low or intermittent.
I was hoping to find a new switch as I hate to put used electronics into my cars, I will if I HAVE to but would rather not.
I need to pull it into the garage and tear into it a bit, just wanted a switch on hand to put in while I'm doing it.
Old Apr 30, 2014 | 08:12 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check to see that all screws are in wiper motor cover and they are tight.
Poor ground transfer between motor and cover, gave me similar problems.
To need a switch
