1985 corvette
Old May 24, 2014 | 11:34 AM
gremlin12's Avatar
gremlin12
Default 1985 corvette
took my 1985 corvette to get new injectors and they replaced them can not get it ti rev over idal what can it be
Old May 24, 2014 | 01:05 PM
John A. Marker's Avatar
John A. Marker
Check fuel pressure.....should be about 39 psi with key on, engine not running and the hose to the fuel pressure regulator unplugged.
Check to see if cables to TB are all connected properly.
Exactly what is happening when you try to give it more throttle?
Old May 24, 2014 | 03:12 PM
DanielRicany's Avatar
DanielRicany
Check engine light on? MAF sensor plugged in? I was experimenting one time and found out that the engine will not rev with the MAF sensor unplugged.
Old May 24, 2014 | 11:02 PM
gremlin12's Avatar
gremlin12
will not rev up
Old May 24, 2014 | 11:03 PM
gremlin12's Avatar
gremlin12
ok will let them know about that thx
To 1985 corvette
