Window switch
Old Oct 27, 2014 | 08:01 AM
BUNGERV87's Avatar
BUNGERV87
Default Window switch
How do I replace the window switch on a 87?
Thanks Bill
Old Oct 27, 2014 | 10:18 AM
don hall's Avatar
don hall
'86 should be the same as '87:
http://www.ehow.com/how_7691066_repl...-corvette.html
Old Oct 27, 2014 | 12:06 PM
BUNGERV87's Avatar
BUNGERV87
Originally Posted by seabright
The window switch on a 87 is on the center console by the shifter.
Old Oct 27, 2014 | 02:58 PM
don hall's Avatar
don hall
My apologies.... some days I'm not very helpful.
Old Oct 28, 2014 | 01:33 AM
Cliff Harris's Avatar
Cliff Harris
You have to remove the top cover on the console. To do that you first have to remove the instrument cluster bezel, then the center bezel. All these pieces interlock and they have to come off in the correct order. You can remove all the screws for the instrument bezel and move it to the side far enough to expose the center cluster bezel screws.
After you get the console cover off the switches are exposed and held in place by two Philips screws. The switches pass a lot of current and the connector is VERY tight. Watch out when you are prying the connector off. It's easy to short something out and blow a fuse.
Old Oct 28, 2014 | 06:24 AM
HlhnEast's Avatar
HlhnEast
The switch is in a bezel (where the philips mounting screws are at) that is a PITA to get off so be careful not to break it. A couple of small blade screwdrivers will help. They are still available but more than the switch. I think I found my switches on the "Bay for less than $10 ea.
To Window switch
