Passive Keyless Entry Light?
Old Oct 30, 2014 | 08:10 AM
moco65's Avatar
moco65
Default Passive Keyless Entry Light?
Last night, the passive keyless entry light came on for the first time in the 2+ years I have owned the car and now refuses to go off - car running, not running, etc...
Should state that I never received the keyless fobs when I bought the car, so have never used those to engage the security system. Truth be told, I rarely lock it at all.
Any ideas as to what to check first? Thx in advance.
Old Oct 30, 2014 | 10:30 AM
markKlein's Avatar
markKlein
Here is a file that might help.
File Type: doc
Old Oct 31, 2014 | 06:13 AM
moco65's Avatar
moco65
Perfect... thank you for the help. Will try this weekend.
Old Nov 1, 2014 | 08:55 PM
pcolt94's Avatar
pcolt94
Normal operation is the PKE light comes on for a 2 second test and then goes out when the key is first turned to on. If the light is on and does not go out, that is a major fault. It is controlled by the PKE receiver solely and nothing else really has any input to it for the self test.
Most likely if you have no control over the light, the PKE receiver is defective. To remove the receiver dash pad has to be removed which is a pretty big job. You can either remove the fuse for the PKE or remove the bulb for the light.
It’s best to always state what year your car is because differences vary a lot. PKE is 93 – 96. However the ALDL connectors and pins are different for the self test error codes.
Old Nov 2, 2014 | 08:42 AM
moco65's Avatar
moco65
Pcolt 94 - Thanks for the additional info.
Tried to pull the fuse, but is also associated with the radio. Going to look at the bulb removal.
Car is a 94 BTW.
Old Nov 3, 2014 | 06:43 PM
pcolt94's Avatar
pcolt94
Car is a 94 BTW.
I believe there are 2 fuses for the PKE. I am on a trip so books here or I could advise you with some specific information.
Old Nov 4, 2014 | 08:13 AM
markKlein's Avatar
markKlein
Three, numbers 26 40 and 42 if i remember correctly.
Old Nov 5, 2014 | 09:24 PM
moco65's Avatar
moco65
Thanks for the add'l info. I originally pulled fuse #40, which killed the radio. Will try the other two this weekend.
To Passive Keyless Entry Light?
