Do you need an OptiSpark?
Old Dec 22, 2014 | 01:26 AM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default Do you need an OptiSpark?
Restore spark to your LT1/LT4 motor with this BRAND NEW Distributor from AIP Electronics
This Distributor EXCEEDS OEM specification and comes 100% complete with everything needed including a new Optispark wiring harness.
(Note: Harness may not fit all applications and you may have to use your original harness.) Our AIP LT1 Optical Encoder is temp rated at 330°
and produces an accurate timing reference signal up to 8000 RPM, exceeding the OEM Mitsubishi encoder used in the AC Delco factory LT1 distributors.
This is most likely the best aftermarket LT1/LT4 distributor you will ever come across. Uses AIP's own Mitsubishi Specification Optical Encoder
for the most accurate/dependable LT1 Distributor yet.
1 Year Warranty!
Vented $159.95
Non Vented $169.95
http://www.saccitycorvette.com/AIPOptiSpark.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Dec 29, 2014 | 05:53 PM
Firewalker11's Avatar
Firewalker11
I just wanted to say that I ordered a non-vented Opti for my 1994 coupe and received it within a week. It looks very well made and I hope to have it installed soon. I will report back on my impressions once that is complete for those who might be interested.
Old Jan 3, 2015 | 01:20 AM
SacCityCorvette
Supporting Vendor
Thank you for your business, Firewalker11!
Let us know how the install goes.
Christian
Old Jan 3, 2015 | 02:04 AM
Vetteblack-96's Avatar
Vetteblack-96
Does anybody know if this is a "remove & replace" that the average
guy can do at home or is it a shop event?
Old Jan 3, 2015 | 10:32 AM
chatham's Avatar
chatham
if you can change a water pump you can do this. it is very straight forward and easy to do. this is a great write up so follow it.
https://www.corvetteforum.com/forums...-pictures.html
if you replace your opti replace your water pump as long as you are in there.
Old Jan 3, 2015 | 02:34 PM
auggy's Avatar
auggy
Default Unvented opti
1 Year Warranty!
Vented $159.95
Non Vented $169.95
Does this new un vented opti come now as vented? I have a 94 .
Old Jan 3, 2015 | 06:12 PM
Vetteblack-96
Chatham, Thanks! I can do quite a bit but I didn't want to get in
over my head if it was really specialized. I'll be able to handle it.
Old Jan 3, 2015 | 06:29 PM
SacCityCorvette
Supporting Vendor
Great detailed write up. By looking at this write up, you should be able to tell if you can do the job or not.
Christian
To Do you need an OptiSpark?
