Scanner decision
Old Dec 29, 2014 | 07:22 PM
lectroglide's Avatar
lectroglide
Default Scanner decision
Hey guys never used one but getting interested with these code readers and needing suggestions for one that is reasonably priced yet easy to use for early model C4s.
Old Dec 29, 2014 | 07:45 PM
pezter22's Avatar
pezter22
I have an Autoxray 2500. It reads OBD1 and OBD2. It's pretty easy to work. I'm unsure about other units. I bought this on a recommendation from a auto parts store I spend some time at.
I think OBD2 didn't start until 1996.
http://www.autoxray.com/product_detail.php?pid=126
Old Dec 29, 2014 | 10:29 PM
Patsgarage's Avatar
Patsgarage
I would get a scanner that reads both OBD I (1995 and earlier) and OBD II (1996 and later) codes. I have a Craftsman that does both, I have also used an Innova brand. Both worked well, but it depends on what you want the tool to do. Most basic scanners will only read powertrain codes, not body, trans or ABS codes. To read those codes you will have to step up to a Tech II or similar. For most people the cost of these units outweighs their usefulness. Whatever you choose, I would try it out first (if possible) and make sure it works for you.
Old Dec 30, 2014 | 12:53 AM
lectroglide
ok but why would I want one that reads 96 and later if I have an earlier year car?
Old Dec 30, 2014 | 07:52 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I don't know if you really even want a scanner.
You can get the codes by using a jumper (paper clip) and connecting two pins on the ALDL.
Try looking at
http://tech.corvettecentral.com/2011...trouble-codes/
or
http://www.digitalcorvettes.com/foru...56&postcount=9
Good luck.
Old Dec 30, 2014 | 12:07 PM
1993C4LT1's Avatar
1993C4LT1
Try looking at
or
Good luck.
Old Dec 30, 2014 | 10:14 PM
Patsgarage's Avatar
Patsgarage
I am just going on the assumption that you have another car that you drive. Or maybe you would get something newer in the future. I think a dedicated OBD I scanner would be hard to find, however code readers are readily available. If you are going to make the investment why not get something that would work on more than just one car ?
Old Dec 30, 2014 | 10:18 PM
Patsgarage's Avatar
Patsgarage
[QUOTE=QCVette;1588596311]I don't know if you really even want a scanner.
This method will give you the trouble codes, but no further data. If you just want to pull codes out of the computer, this will work fine. If you want more detailed diagnostic info such as sensor data at the time the code was stored you need a scanner.
Old Dec 31, 2014 | 02:37 AM
Cliff Harris's Avatar
Cliff Harris
In my opinion the best solution is a cable (roughly $70) and scanner software for a laptop. The major advantage is that you can data log and import the results into a spreadsheet. I find graphing certain parameters can give me a much better picture of what the engine is doing.
Here's an interesting example which show how the IAC counts decay as the engine warms up at idle. The default startup IAC count is 144, so that's where it begins when the ignition is first turned on. The coolant was at 91° at startup. When the engine was started the IAC dropped pretty fast to the initial idle speed and slowly tailed off from there until the coolant was fully warmed up.
Old Jan 3, 2015 | 07:36 PM
lectroglide
update>>>>>>your prolly right and have been looking around for one unit that does both
To Scanner decision
