Lost Key
Oh, and emergency hood release cables too.
Did you buy a 1K that's linked OR did you buy a 10K? Actually I don't believe a 10K will do the entire 1 - 15 BUT will do the first 1 - 14. To do a complete VATS you need one of each connected in a series to do the entire range and accomplish coarse/fine adjustment. A 10K RS I believe would be this 271-0343 and maybe an "in store" local if still open or maybe eBay using that #.
EDIT: In fact, HERE is the unit I bought and used...it's up to $3.49 now
After posting the 10K # I searched that number and actually found a post where a user mentioned how you configure "BOTH" to check 14 of the 15 possibilities. I've had a VATS decoder for years and have never used POTS.
Here's that post. Is it correct? I believe very likely.
https://www.corvetteforum.com/forums...post1575086581
That poster mentions "redrose" & "socalman" supplied information he used. If you have questions regarding the POTS contact any of the three.
Design along with minimum/maximum tolerances are posted in a chart in this post:
https://www.corvetteforum.com/forums...post1586339215
I had a friend that insisted on doing his checks in this order: 7 - 8 - 6 - 9 -5 - 10 - 4 - 11 - 3 - 2 - 1 The only year that 1 is significant is '86 so in most instances #1 could be overlooked anyway and was a waste of 5 minutes of time. OP's being an '86 he can't overlook #1.
I wouldn't have thought the key code would have been stamped on an '86 cylinder. There is no way to get any other information from GM for your car. I believe that "CLIFF HARRIS" disassembled a VATS module for an '86 and identified which resistor actually controlled the VATS. You could remove the VATS module and check that way also. In the last link I posted I listed the resistance ID's by stripe codes for I believe the resistors used.
Cliff's images seem to have gone away. I believe he mentioned a .pdf image issue with the CF.
