New headlights question
Old Jan 2, 2016 | 06:48 PM
Mikes93c4's Avatar
Mikes93c4
Default New headlights question
I've read a few threads on here about upgrading headlights and a lot of people seem to have had rewire and switch relays. My question is are they good options that simply involve removing the old light and putting a new one in without messing with wiring.
Old Jan 2, 2016 | 06:50 PM
antfarmer2's Avatar
antfarmer2
are you going to drive it in the snow?
Old Jan 3, 2016 | 01:23 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Your headlight motors and gears will last much longer if you buy new ones that are listed for the 95/96 Corvettes. They are plastic and weigh considerably less than your glass units. See if you can get Silver Stars in plastic as they are much brighter.
No wiring changes needed. Plug and play.
Old Jan 3, 2016 | 10:09 AM
dizwiz24's Avatar
dizwiz24
my problem with these 'plastic units' is they are still the same crappy 'i cant see when driving the vette fast at night' headlight.
i personally think the heavy headlight cAusing gear wear problem is either
a. overblown
b. was fixed by my model year (93)
i cant speak for the silverstars (or newer ge nighthawk led's) but ...
i have never had any headlight issues and use heavy glass optics 'cibie' h4 conversions from daniel stern which allow me to see the road clearly vs. the stock POS headlight units.
is their better and lighter technology out there now? yes and i dont know what it is...
i advise against stock plastic headlights As the lighting from them 'stinks'
Old Jan 3, 2016 | 11:17 AM
c4cruiser's Avatar
c4cruiser
a. overblown
I had used the Hella glass conversion lamps in my old '92 and never had a problem with the motors or gears. I also used a Xenon H4-style bulb (100W/90W) and never had an issue with the wiring or OEM relays. A separate relay could be added so you could use a dedicated 12v power source that would provide more amperage, but I didn't seen the need for it at the time. One thing I really liked about the Hella lamps was the beam pattern. More light to the right side and a very sharp horizontal cut-off so glare from rain or fog was pretty much eliminated. CIBIE lamps would be an equal.
Lamp assemblies like the Hella or CIBIE units can be pricey, but IMHO, they do a better job than lamps like the SilverStar or other similar lamps. These lights have pretty much the same wattage as stock light; the only real difference is the bulb color temp (3500k for stock, 4000k for the SilverStar and similar)
Old Jan 3, 2016 | 12:09 PM
antfarmer2's Avatar
antfarmer2
useing stock wireing your not getting all the light from 90/100 I would not push my wireing that far.
Old Jan 3, 2016 | 01:43 PM
1984Z51auto's Avatar
1984Z51auto
I have used Hella conversions with the "stock 55/60" watt H4 bulbs that come with them for years and been happy with the results. They are euro standard with the sharp beam cut off and right hand kick up and do a good job at legal speeds. If you need more light the higher wattage H4 bulbs will do it but, you really should then add lighting relays and heavy duty plugs and heavy/dedicated wire to protect the switch and stock headlight circuit.
Old Jan 3, 2016 | 01:54 PM
maddogwyatt's Avatar
maddogwyatt
a. overblown
them 'stinks'
Old Jan 3, 2016 | 03:50 PM
Mikes93c4's Avatar
Mikes93c4
No snow for my vette. Just looking for something brighter/lights more road
Old Jan 3, 2016 | 04:26 PM
dizwiz24's Avatar
dizwiz24
totally agreed which is why i followed directions from daniel stern lighting website and used heavy 10 ga (likely overkill) wiring direct from my battery and relays off the stock wiring (stock wiring is the 'trigger' to activate the relays).
my lighting is amazing, but there is likely better less alternator power robbing technology out there now.
my clear halogen Narva headlight bulbs are both 100 low/ 130 watts on high.
so that means 260 watts to operate my high beams!!!!
Old Jan 3, 2016 | 05:48 PM
Mishawaka's Avatar
Mishawaka
This s what I bought. Cheap, easy install, has a glass lens, no special wiring and much brighter than the factory headlights.
http://www.ebay.com/itm/130962776125?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jan 5, 2016 | 10:29 AM
dizwiz24's Avatar
dizwiz24
7x6 H6054 H6052 H6014 Head Light Housing Lamp Conversion Chrome Diamond Cut T | eBay
i tried a similar brand 'diamond cut' headlight kit and returned them. the kit i bought looked just like that - with that dish over the bulb end
beware the reflector optics arent same quality as bosch, cibie, or hella.
though i need to say the bosch and cibie are superior to hella (for low ride height cars).
the issue i had was if you adjust low beams to see the road, then the high beams are up in the trees and not on the road.
the bosch and cibie housings, bought thru daniel stern lighting, font have this issue
Old Jan 5, 2016 | 10:44 AM
antfarmer2's Avatar
antfarmer2
D.S does not make them I have cibies and work great not sure what could be wrong. the only thing you can do wrong is put them in upside down. what kind of bulbs are you useing?
Old Jan 5, 2016 | 04:31 PM
Mishawaka's Avatar
Mishawaka
What ever came with them, but need to check because although they are bright enough I thought about going with something even brighter. Bought a ceramic pigtail and thought about putting them on a relay so I don't burn up the headlight module.
Old Jan 5, 2016 | 04:43 PM
antfarmer2's Avatar
antfarmer2
if you don't use heavy gauge wire you won't get all you can out of a bulb over 55 watts.
Old Jan 6, 2016 | 01:49 AM
Cliff Harris's Avatar
Cliff Harris
The stock headlights are rated at 35W on low beam and 65W on high beam. That's roughly 3 amps on low beam and 5 amps on high beam.
Old Jan 6, 2016 | 08:24 AM
antfarmer2's Avatar
antfarmer2
brighter is better to a point it is more about directing the light to where it is needed and not blinding folks.
To New headlights question
