Does parking lever push down??
Old Aug 20, 2016 | 05:07 PM
Atomic6's Avatar
Atomic6
Default Does parking lever push down??
I just replaced the inside console and everything fits wonderfully but I notice when I put the lever into Park the plastic P R N D piece is pushing down and I'm afraid it is going to break. It''s fine and level in all the gears except Park. The indicator seems to go a bit north of the P. Is that normal? The prongs lined up fine when I installed it.
Old Aug 21, 2016 | 05:53 AM
Atomic6's Avatar
Atomic6
My title probably should have said 'shift' lever. Can't edit it.
Old Aug 21, 2016 | 09:57 AM
markKlein's Avatar
markKlein
No, that is not normal.
Old Aug 21, 2016 | 11:18 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
You need to take it apart and be sure the indicator is in its proper place. Should fit a pin on shift lever and in a grove on indicator.
Old Aug 22, 2016 | 06:30 AM
Atomic6's Avatar
Atomic6
Yes, it does fit right. The pin is right in the middle of the groove. It's just the Park position that puts the down pressure. It goes too far forward past the 'P'. It might be one those 'oh well' situations until it breaks. Too bad because the car is so darn perfect other than the headlights which I'm still working on getting fixed. I sure could use a good Corvette shop. Still hunting.
Old Aug 22, 2016 | 06:34 AM
antfarmer2's Avatar
antfarmer2
Youtube
Old Aug 22, 2016 | 08:42 AM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Originally Posted by antfarmer2
Youtube
Do a search on adjusting the cable
Older C4 not sure if the 96 is the same.
https://www.corvetteforum.com/forums...djustment.html
http://www.corvetteactioncenter.com/...ft-adjust.html
To Does parking lever push down??
