Heater core. How Hard?
Old 10-02-2016, 02:43 PM
confab
confab's Avatar
Originally Posted by kael
May I get a direct link to the forum, please?
I've searched and searched, nothing showing up.
Supposed to be "fast guy method" in title, right? This discussion?
No, it is the username.
Thread is here:
https://www.corvetteforum.com/forums...etty-easy.html
kael (10-03-2016)
Old 10-02-2016, 06:23 PM
BLUDICE
BLUDICE's Avatar
So from what I'm reading it sounds like the later C4 owners have to pull the dash??!!
Old 10-08-2016, 07:40 PM
confab
confab's Avatar
THANK YOU Fastguy!
About an hour (Because I left the seat and stuff out to put in the rest of the new carpeting.)
Otherwise? Like he says, about 2 hours. Right on the money.
If anyone is doing an 85, HELP! Package 75450 has the clip you will break. (may fit other years, I dunno?)
It is 4 bucks at Advance Auto.
W@@T!!
Old 10-10-2016, 03:41 PM
Raidmagic
Raidmagic's Avatar
I'm late to the party but that's the best way to do it. I did mine before seeing that thread. I had the car apart so many times the thought it taking it apart didn't bother me so I figured I'd try to do it another way than the book. I did it much like he did
Old 12-06-2017, 09:19 PM
Matt Pegis
Matt Pegis's Avatar
I’m stuck on the last bolt, bottom three were cake, top left needed a tool I did not have, top right I can’t imagine
a tool which will reach it, I can’t touch it and can only see it with an extendible mirror. What did you guys use?
mine is an 87.
Old 12-06-2017, 09:36 PM
VikingTrad3r
Oil Producer
Support Corvetteforum!
VikingTrad3r's Avatar
Received 2,270 Likes on 1,452 Posts
mine is an 87.
on the top hidden onr i have taped the screw to the nut driver and Used a mirror to line it up.
the second time, i used tape!
Old 12-06-2017, 10:28 PM
xrav22
xrav22's Avatar
On the top hidden one I used a single large hex key taped into a long 1/4 extension with the proper sized socket. No room for the bulk of a ratchet.
Old 12-07-2017, 02:11 AM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
A simple mod I made to the 86 was to pin the water control valve in the open position.
This keeps water flowing thru the core, rather than stagnating and causing corrosion.
When the summer gets too hot you can always pull the pin.
Old 12-07-2017, 09:07 AM
FOURSPEEDVETTE
FOURSPEEDVETTE's Avatar
Another vote for The "Fast Guy Method". I did it on my 1985. About 4 hours for me total. I could not get to that top bolt on the cover! So I just wiggled the cover back and forth until the plastic snapped around the bolt. I removed the cover then. Afterwards I just put the cover back on and didn't use that bolt. No problem. Definitely buy that plastic clip for the rod on tne heater box door.
Old 12-07-2017, 09:56 AM
CCRed
CCRed's Avatar
Hell, I spent that much time changing ONE outside tail light bulb.
Old 12-07-2017, 10:57 AM
FOURSPEEDVETTE
Now THAT'S the job I'm dreading doing!
Quick Reply: Heater core. How Hard?
