Headlight switch
Old Feb 6, 2017 | 01:05 AM
Luci's Avatar
Luci
Navigator
Default Headlight switch
Can't shut headlights off I push the switch in and I get no response so I disconnected the battery so it wouldn't kill it for the morning this is my daily driver any help would be appreciated! Thanks Luci
Old Feb 6, 2017 | 01:24 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
What year?
Old Feb 6, 2017 | 01:35 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Sounds like a switch. If you do not know how to check it then find someone that can do it for you.
There is a harness connector near the front of each inner fender. Check for corrosion in the connectors and for frayed/broken wires too.
Old Feb 6, 2017 | 06:16 PM
Luci's Avatar
Luci
Navigator
Default Thank you for all responses! I have more problems! Lol
Thank you! It's a 1987 z52. I brought it to my mechanic the dash was cracked behind switch! The switch was still good! Now the headlights have a problem they never had before one flips half way up and the other doesn't flip up at all. What do ya think? Thank you!
Old Feb 6, 2017 | 09:21 PM
JrRifleCoach
Plastic gears in the bucket drives have broken.
Common for this model to have fail.
Old Feb 7, 2017 | 01:00 PM
Luci's Avatar
Luci
Navigator
Default 1987 Headlights
Thank you so does that mean I need to have new motors installed 😩
Old Feb 7, 2017 | 04:50 PM
hcbph's Avatar
hcbph
In all likelihood you can rebuild them or replace them totally - your call. Check around here, I've seen threads on others that have replaced the plastic gears (also pucks in some cases) and didn't look terribly hard but I have not done it myself.
Old Feb 7, 2017 | 07:36 PM
Luci's Avatar
Luci
Navigator
Thank you so much for the info!!! 😊
Old Feb 7, 2017 | 08:08 PM
Luci's Avatar
Luci
Navigator
Originally Posted by jrriflecoach
what year?
1987 🏁🇺🇸
To Headlight switch
