coolant lines / throttle body
Also, I think there is an additional fuel economy benefit to heating up the blades, the air passing by has to hit, or pass by, the hotter throttle body, which should help to reduce air density by how little it does. This in turn improves fuel economy while MARGINALLY reducing horsepower. However, are you really that pressed for a marginal gain in HP?! The throttle body airfoil is far more effective!
Not sure how to measure that but winter fuel would suck whatever you gained.
Honestly, if it truly doesn't perform it's function for winter driving, then my only guess as to why GM would have designed the throttle body to run coolant through it would then be to intentionally heat up and reduce the density of airflow for a marginal increase in fuel economy. I want to make it known that I did this modification on my own car in the past and from memory, I hardly noticed any performance improvement but during winter the car seemed sluggish and it did consume more fuel. The only reason my car is back to using the factory set-up was that my mechanics shop reversed my modification without me knowing it and I didn't discover this fact until some time later, the bastards, they kept my end caps and everything. However, the car really didn't suffer *AND* fuel economy was marginally better, but that was with the factory WS6 ram air box, but plastic degrades and this factory mold was starting to split apart allowing unfiltered air into my motor, which is why I have a much better factory LS1 air box from a Camaro on my car! My fuel economy improved a tad and driving around winter with deactivated ram air nostrils in the hood, the motor actually seems to run better with warm engine bay air, despite the obvious reduction in power. This is how a mad scientist with a sports/muscle car finds ways to balance power with fuel economy.
2. you're not heating the blades. You're heating the housing. Even if there were a fuel economy gain, it would be for different reasons than you cited, and it would be just as MARGINAL as your power loss (worthless)
2a. if you really want to see an improvement in vaporization of fuel due to hotter inlet air, a heat stove on the exhaust (like seen on older carb'ed cars) would be massively more effective.
3. The OP removed the feature b/c it was leaking...not b/c he was "really that pressed for a marginal gain in HP".
Nope, GM did not add a coolant passage to the TB, to reduce air density (on a performance car). They did it because that they have to meet criteria that we don't and we don't care about. Like running at 40* below zero, for example. Most of us don't operate under those conditions, so we can make changes that have no meaningful negative impact.
Can someone quote this so Penix can see it please?
I generally dismiss what people say they felt, feel or will feel simply because the butt dynos are too crude and subjective. You won't feel a 1 HP difference, for example. Show me a dyno sheet and I believe you.
IDK if I call the subjective assessments science but others might.
Oh, by the way, let me help you with your poor illiterate spelling. It's Phoenix, p.h.o.e.n.i.x! I can forgive you.
Well I just bypassed mine and I can feel the improved acceleration. No question.
Wait maybe it was the new plugs, wires, coil, opti, TB cleaning. Nah, I think the real horsepower gains came from rerouting a 1/2" cooling line.
GM would not have spent the extra money to flow coolant through these throttle bodies if there was not some particular reason, whether it being as minor as winter driving purposes to possibly trying to warm up incoming air by having it collide with a hotter throttle body versus one without hot coolant running through it.
We are not talking about the size of the inlet for the throttle body, we are talking about the nature of warmer/less dense air to colder/more dense air. This property is already well known by those trying to squeeze more power out of their internal combustion engines. So, yes, despite the throttle body coolant system NOT being something connected to the hottest part of the exhaust system, it still serves to improve fuel economy, and even a marginal gain per mile is an improvement during the winter.
Again, for profit sake, GM would not have added the throttle body coolant system if it served no purpose.
Even, then if it is better to drive your car with the throttle body coolant system in use during the winter, then what is the problem? As I have said, despite the obvious loss of power which I don't need it for winter driving, the car runs very smooth, and I have noticed the mileage is a little better before encountering below 30 degree temperatures and snow. I am willing to try driving around in the spring with the ram air hood deactivated to see how much of a mileage gain this set-up gives me. It may have me considering a custom cowl hood using my factory WS6 hood with whatever engine modification I decide to go with
IIRC, the intake was a truck intake? For a truck that sits outside in cold areas, it could make sense. If so we might be getting a "hand me down", essentially.
How marginal? As marginal as the loss of fuel economy with winter fuel? We know that has less BTU.
Agreed but whether that purpose is useful to a C4 is the question.
How much loss? How sensitive is your butt? How did you determine the fuel had no effect?
Or maybe the angle of the dangle or the road?
Well, I noticed a difference of at most two miles per gallon compared to my mileage without the use of the throttle body coolant. I log it on the EPA fuel mileage site like the Eco-Modder dork that I am. So, using the throttle body coolant system, it makes up for the loss you experience in fuel economy during the winter BUT come spring and summer you should be able to gain that much to your normal fuel mileage. Basically it is just playing a balancing game between fuel economy and how much power to give the motor, or really, modifying the motor to breathe in more warm air! It sounds self defeating but I am crazy enough to play around with the notion.
While a warm TB MAY provide an infinitesimal increase in fuel economy it's not because of the reason you WAG'ed (lower density). You control air density with the gas pedal. For the second time, any minute increase in fuel economy would be as a result of better vaporization.
FYI, I'm still getting the same (hand calc'ed) -or w/in 1 mpg- gas mileage that I got all summer. What ever the diff...IF there is any, is too small to observe in hadn't calc's every tank... in my TB bypassed car, so...You're really grasping at straws here with the fuel economy thing.
Let me ask you this; if you're so convinced that fuel economy is a meaningful factor in implementing the TB/coolant feature...then why didn't GM run coolant through the entire intake plenum? Imagine the fuel economy!!
In fact, with the LT1, they removed coolant from the intake that the previous L98 had. OR
Why didn't GM retain the "heat stove" philosophy that was in place on earlier carb'ed TBI engines? That would likely be cheaper than the TB coolant passages, it would be WAY more effective at feeding HOT air...and just Imagine the fuel economy!!
All this from the guy that thinks more vacuum = better fuel economy, strokers will ruin fuel economy and gears will cause him to accelerate too fast. I told you why GM did it; criteria that we don't have to meet and don't care about.
Interestingly, the GM TBI truck engines of the era didn't have any provisions for a TB coolant system. They did have head stoves though. Anyway, their replacement, the L31 Vortec had no heat stoves nor any TB coolant provisions. How to they manage!? Can you imagine the fuel economy that's been left on the table with those engines!?
Air density is determined by other factors, most of which we have little to no control over (air temp, altitude, barometric pressure, dew point, etc.)
The air density inside the plenum/runners/cylinders is managed with the throttle pedal. Pheonix (the poster who I was replying to) was talking about air density inside the plenum. You manage that with your right foot.
If you want to argue semantics, then yes, TB controls air flow. What do you suppose happens to the density of the air in the plenum when we increase airflow (with the gas pedal) into the plenum? The density increases. What happens when you take your foot off the gas pedal? Throttle plates close, air flow dwindles, density in the plenum drops. We control the density of the air in the plenum with the gas pedal....not the temperature of the TB (which phenoix was trying to claim when he said this:
"my only guess as to why GM would have designed the throttle body to run coolant through it would then be to intentionally heat up and reduce the density of airflow for a marginal increase in fuel economy."
I was responding to that. No. GM is NOT trying to manage air density in the plenum using temps and/or heated TB's. You control air density in the plenum with the gas pedal.
In fact, with the LT1, they removed coolant from the intake that the previous L98 had.OR
