Very Seriously Considering this C4...
1989 Chevy Corvette Roadster. Excellent condition with original paint. Approx 58k miles. No accidents, never hit. Last year of the "Atari" interior and first year of the ZF 6 speed manual transmission. Ice cold AC. Runs fantastic. Cloth top and back window are in excellent condition , hard top with stand also included. Two sets of factory keys and a service manual included. Clean title in hand and will smog for the next caretaker. Everything works as it should . Ready to go.
$11000
Work done over the past year:
Headlight motors rebuilt with new nylon gears
New Aluminum high performance radiator
New hoses and thermostat
New alternator an Bosch Battery
AC Delco spark plugs and wires
New distributor cap, rotor, and coil
Engine idle air control valve
Fuel filter , screen, and pump
Blueprinted and flow-matched factory Bosch fuel injectors from the Injector Connection
EGR temp sending switch, solenoid vacuum relay and EGR valve
New wiper blades
New catalytic converter
Magnaflow cat-back stainless exhaust
New door window outer seals
New door interior courtesy lamps (LED)
New cabin cover (for use when the top is down)
Power steering system flushed.Attached Images
Join a local Vette club and get a recommendation for a good C4 mechanic to do a pre-buy inspection. Minor issues like weatherstripping that needs to be replaced, poor performing Bose radio, etc. can be negotiating points on price.
$11000
New wiper blades
it does have the ZF6 trans, which is a nice plus too. And, it IS a convertible; both are premiums.
Compression check results? brakes as new?
A ZF6 is a maor PITA in stop-and-go driving. I lived in San Diego with mine for eight years, and hated the car when I got on the I-15 or the I-5 or the 405.
https://www.corvetteforum.com/forums...low-miles.html
I would buy that car.... its a forum member.... he has extensive maintenance records... I would bet he might make a concession for the worn drivers bolster.... The car is well cared for and looks to be in top shape. I had a beautiful 86 coupe I just sold last month that I started at $11,000. I would have gotten that, but I was in a bit of a hurry to get the ZR-1 I have.
As stated, the CF car sale section is not the best place to sell a car. We already own at least one. We do use that section “gauge” the value of the cars we already own.
When I sold Vettes in the past, I used CL during Corvettes at Carlisle or bought spaces in the car corral. Always got cash ( as in 50’s and 100’s)
And most of the time they were heading out of state.
In ending, grab it if you want it. If you have the means, a good deal is when both the buyer and seller feel good in the end. Not necessarily the amount of cash that changed hands.
There, I’m off my “soapbox”
records are all the difference.While I don't like throwing money around I have made the mistake of passing on a good car to "save" $1000 and spent thousands more than I had to on repairs becasue I "saved" $1000.
Don't get so caught up on the price and put more emphasis on condition, records and maitenance.
