The acrylic roof has begun to separate from the frame and lifts up and down causing painful changes in air pressure. Is this common and if so what can I use to reseal the acrylic to the frame? Thank you
DON"T DRIVE THIS CAR! The roof will fly off unexpectedly, with tragic results!
Here's a link for re-bonding your acrylic roof. I did this procedure to my car many years ago, and it's working just fine! Don't try using RTV or weatherstrip adhesive. That will just make a mess that will complicate your next inevitable repair job. https://www.corvetteforum.com/forums...ir-advice.html
