The right rear tail light:
1. Turn on the lights, left and right work.
2. Turn on the right turn signal, it does not work. Turn on the left turn signal, it does work.
3. Left rear brake light works. The right one does not.
4. Turned on the right turn signal and attached an ohm meter. .8 on the right inner bulb contact. 0 on the right outer bulb contact.
