This is probably another repeat question. 89 Vette. Looking for a 12 volt, ignition controlled source, somewhere under the dash on the driver's side. Looking to add a couple of aftermarket electronic gauges.
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
There are 2 spare wires under center counsel for acc. use, 1 hot all the time and 1 with ignition or acc. on. I forgot what colors are but they have scotch-locks and should be easy to find.
Originally Posted by The Green Hornet
Page 124 of my owners manual explains how to access accessory wiring plug.
'91 is the 'first year' for the wires you mentioned.
If you're up to it you could add in a relay and just trigger it off an existing circuit like the ipc or just use an add a fuse on the fuse panel on the passengers side.. Unless those circuits aren't ignition switched at the panel. In which case I would do the same just tapping from the ignition wire and use a relay under the column.
Haven't looked at this post in a few days. Cigarette lighter is not ignition controlled. Hot all the time. I ended up tapping into the radio power source, and all seems to be working fine. The two gauges I hooked up to it use very little juice, so all should be well. Thanks all for the info.
