Replacing the Bose System
thank you
jim
If you are a 91 coupe and not ZR1 like mine is, I would say go buy the rear speaker enclosures for NON-Bose. Go to Crutchfield to see what will fit into a non-Bose system for speakers and what you need for head unit.
Run wires from the head unit to the rear with a foot extra length. Put the speakers in and wire that sucker up.
You can reuse the Bose speakers Amps w/an aftermarket head, if you spice RCA cables into the Bose amps.
Or you can gut the whole system and install any aftermarket system of your choice. What's most affordable? IDK....some "system" from Walmart? Autozone? What MOST affordable is a system pieced together from your local classifieds. I put an entire system together for my boat (Alpine HU, JL sub, Eclipse amp, Pioneer 6x9's in boxes and an Alpine 6 disk changer) for a grand total of $90 and the thing rips.
can I use the exsisting speaker wires that go with the Bose system or do I have to go ahead and got everything does anybody have the wire diagrams so I know which ones power and so on it's a 1988 C4 thank you guys
one more thing I did take the back passenger side speaker out I have one hell of a time getting that out but I got it so it looks like a 6 by 9 speaker will fit right in that in area is this true
UOTE=rgauchey;1597881236]I replaced mine and never tackled a project like that before. I recommend Crutchfield as your source. They provided me with everything I needed. Bose bypass harness from them made it almost plug&play. I installed new speakers and ran new speaker wire. I wasn't about to use 30yo parts in my new system.[/QUOTE]
Maybe you can hire out that part and watch them? IIRC, Best Buy didn't care I watched.
And you wonder why I consider a long life a curse.
Don't know why you'd pay for a "bypass harness". All you need for a new system is:Batt power
Keyed power
Ground. Everything else (line wires, amp power, speaker wires etc)...you're running new/custom. Don't need any harnesses for that...or any bypasses either.
Front right speaker Black = Amp Ground
Front right speaker Lt Grn = Line level "+"
Front right speaker Dk Grn = Line level common "-"
Front left speaker Pink/Blk = Amp +
Front left speaker Black = Amp Ground
Front left speaker Tan = Line level "+"
Front left speaker Grey = Line level common "-"
Rear right speaker Pink = Amp +
Rear right speaker Black = Amp Ground
Rear right speaker Dk Blue = Line level "+"
Rear right speaker Lt Blue = Line level common "-"
Rear left speaker Pink = Amp +
Rear left speaker Black = Amp Ground
Rear left speaker Brown = Line level "+"
Rear left speaker Yellow = Line level common "-"
https://www.corvetteforum.com/forums...ry-wiring.html
Bought my stuff at carstereosonline.com.
