Wanting to lower engine temp.
With no stat, the car will run as cool as the capacity of the system will allow. Most of the time it'll run much cooler, but in HOT ambient temps under a higher load, it'll end up ~200 or so with or without a stat. It could help....but it's not the right way to manage your operating temps.
I agree with the poster who recommended cleaning the radiator. I'd also flush the cooling system and it should then run "down against the 'stat" about any time you're underway and have air flow.
1. Lower temp thermostat
2. Fan on/off temp lowering
3. Oil cooler
This is all assuming you’re running the right viscosity oil, cooling system serviced/good working condition, radiator area is clean of debris and obstructions. I have items 1 & 2 done.
Whether or not that temp your running at is normal, well that’s a separate discussion but many wouldn’t have issue with it.
Second - Do not put a 160 stat in your car. Not to start a thermostat war but your car was DESIGNED to run a specific temperatures. Most of the overheating is just a mental concern for most people. Look at the service manual and if you fall within normal driving conditions then it's not a problem that needs to be fixed. Also, to cool of a system is not always better especially if the car is not tuned to take advantage of that additional cooling. A car that runs 215 degrees with a 195 stat will not run cooler with a 160 degree thermostat. It will just delay the time it takes for the car to hit 200 degrees as both thermostats will be fully open at that point anyway. Above about 40-50 MPH the stock fan actually becomes a restriction to airflow so if you are running hot while moving it's not an airflow problem but the cooling system (poor flow, blocked radiator, etc). If your cooling problem is below 40-50 MPG and not above it's an airflow issue (fan).
For your specific issue, I think you more than likely have a sensor calibration related error.
It will not make a car run, "much cooler".
The heater core holds about 1qt of coolant. Maybe 2 on a large one (like a Suburban or a Jeep Wrangler).
The heater core sits in a box. When the heat is off (which is the condition that you originally referenced) there is virtually no heat transfer out of the water going through the core. How could there be?? The core is in a box that is as hot as the core. Keeping the context consistent let's review:
"I’ve been able to drive my over heating Jeep back from trail riding on the highway more then once with the heat on and gotten as much as 10 degree drop in temp. Just enough to keep the Jeep from over heating."
I'm pretty sure that's an oxymoron. Was it overheating or wasn't it? The heater core isn't going to prevent overheating. With the heat full on, obviously you're pulling some more BTU's from the system, but not a lot, and that isn't what you originally said anyway. If you don't agree with any of this....PROVE IT. Take your sons car, run it on a specific loop. By pass the core, run the same loop, same speed, same ambient temp....then report back. I have already done this, in my many years of cars and mechanics. The heater core with the heat full on will make a very marginal difference (maybe like the 10* you mentioned).....a heater core sitting in a hot, heated box w/no air flow ain't gonna do SQUAT. Sorry, but it won't. You asked if your theory was fact....no, it's not.
