So my left headlight was winking and motor running so broke it down and replaced the small gear that lost teeth. Everything went smooth and thought it was fixed until I put it all back together and now the motor won’t engage. If I give it a nudge it slowly opens and that’s it. I did a troubleshoot and turned the lights on with the motor disconnected from the light and it spun so the issue it’s having is with the resistance from being connected to the housing. I do know the previous owner replaced the motor and it was working but it was obvious there was a bad gear he didn’t fix. I know I put it all back together correctly so I’m at a loss. I know there’s been similar issues but nothing like this.
It's not clear what you're trying to tell us. How can the motor spin if you disconnected it?
How could the motor work properly if it had a bad gear? This doesn't make sense, either. Things do have a way of failing with no previous warning, you know. Don't be too quick to blame the PO.
I dont believe so. I made progress this afternoon as was able to replace the large gear that wound up having broken bushings and also had to align the light perfectly so that it didn’t make any contact with hood. All SHOULD be working properly but the motor moves much slower than the passenger side. Then only sometimes it goes down but it does go if I give it a nudge. I’m thinking maybe the mechanic that replaced this motor didnt use the right one or the mtoot has worn out from constant spinning when the gears were worn. All electrical contacts seem to be adequate. Just seems the motor is having trouble with the resistance
Not sure if I’ll still get responses to this old thread but I’m narrowed down to either the relay or motor being the issue. I checked voltage on the last connector and getting 12V at Grey when off and I think green when on. Therefore I imagine my switch and relays are good? If that’s the case I’m guessing I dislodged the connection into the motor itself when I changed the gears that were stripped. If anyone has any tips or videos to working on this headlight motor specifically that would be great. It’s just frustrating that the previous owner had a shop replace this motor and when I bought it the motor did run in both directions, unfortunately just not down now.
It is important to lubricate the motor shaft bearings with a light weight white grease, like LibriPlate or CRC StaLube. The motor shaft needs to move on its axis (in addition to the normal rotation) in order to actuate the limit switches when the headlight door hits its stops. Also, be sure the limit switches on the motor shaft are clean.
Do you see any indication that the armature might be dragging on the motor magnets?
In reading that what I think my problem might be is I possiblly have the magnets surrounding the copper in the wrong direction. At one point it became dislodged so I kind of spun it until it sat back in comfortably thinking that it wouldn’t make a difference. I guess maybe I’ll have to take a look through additional pictures to determine how it should be sitting. Hoping it’s that and if not I imagine it’s the 1. brushes being worn where it’s contacting the commutator, 2. The actual wiring into the motor having poor contact or 3. I have my magnets spun improperly.
Thoughts?
