Hate my rubbery gear shift console
Old Mar 24, 2019 | 05:57 PM
Stepps's Avatar
Stepps
Default Hate my rubbery gear shift console
Anyone know if there's a kit or ANYTHING I can replace my gear shift console with? My 94 coupe it's like a rubbery finish that is sticky to the touch and really just a dirt/dust attracter. It truly is horrible. Any input at all would be appreciated, also is it really involved to change it if there is something I can replace it with. I want to keep the car all original so will this effect that for a future statement of "all original". I have replaced the radio but I've kept the original equipment to return it back to stock someday if I should decide to sell it.
Old Mar 24, 2019 | 06:12 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Is this the issue you are referring too?
https://www.corvetteforum.com/forums...e-cleaner.html
Old Mar 24, 2019 | 06:15 PM
gpierce's Avatar
gpierce
I think you have four choices:
1) Live with it
2) Buy new repro replacements
3) Strip the coating off yourself and leave it that way
4) Strip the coating off and re-coat with something else (vinyl, paint, etc)
Old Mar 24, 2019 | 06:32 PM
95LT1ZF's Avatar
95LT1ZF
Not sure who, but one forum member used purple power to get off all the rubber coating and then painted to match the ret of the console. Looked really good, but he said it took a LONG time to get the coating off.
Old Mar 24, 2019 | 06:37 PM
WhiteC1's Avatar
WhiteC1
Default Console
Stepps,
I just finished my console using Joe C’s method. I think it came out great, and I won’t have to deal with that Dulso crap... Check out my post just below for pictures.
https://www.corvetteforum.com/forums...post1599101361
Regards,
John
Old Mar 24, 2019 | 07:13 PM
belairbrian's Avatar
belairbrian
I bought a gallon of purple power and a tub from walmart. I soaked the panel overnight and the Dulso fell off. Washed it, media blasted it, and use trim restorer as JoeC came up with. The best thing about this is there is no coating or paint to scrape off. I also did my radio surround panel and center vent.
Old Mar 24, 2019 | 08:38 PM
RedRedRed's Avatar
RedRedRed
The exterior window trim on C6s has a sort of rubbery coating on it and forum members said that RainX worked to get it off. I was skeptical, but it worked like a charm. I'm not sure if it's the same coating or not, but it might be worth a try. Didn't take much effort, and you wouldn't have to disassemble anything, just rub it on with a micro-fiber cloth.
By the way, I don't have access to my '91 right now and I haven't had it long enough to have noticed. I don't think it has the same coating, does it? It has the grey-ish panels that were used on the '90 and '91.
Old Mar 24, 2019 | 08:48 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
I have a new one to install, but decided to experiment on the one that my wife's dog scratched. (no more dog in the car). I took it out, cleaned it and sprayed it with spray on liquid black tape, as sold at Harbor Freight. Then I wiped it down with Armor All. It ended up creating a texture very close to the dash and isn't sticky. Eventually I will replace it, but for right now it alleviated the little bit of OCD that I have.
Old Mar 25, 2019 | 05:19 AM
Stepps's Avatar
Stepps
Thank you but if I buy a repro replacement isn't it gonna just be the same dulso material or no???
To Hate my rubbery gear shift console
