Poorvette
Old May 16, 2019 | 09:28 AM
rbates74's Avatar
rbates74
Its worth mentioning that there is a 2 inch intercooler raising that up. Without it I think it would fit under the hood. I had already removed my hood for a stealth ram swap.
Old May 16, 2019 | 09:32 AM
pacoW's Avatar
pacoW
There's already a "Leroy", I watch him on youtube all the time. So what are you going to name your project? I would suggest "Brandi-Lynn".
Old May 16, 2019 | 09:57 AM
JoeNova's Avatar
JoeNova
Its amazing how upset C4 owners get when you peel away all of the 80s styling and start making chassis/power improvements.
Old May 16, 2019 | 09:58 AM
856SPEED's Avatar
856SPEED
Poor Vette...perfect thread name.
Old May 16, 2019 | 10:04 AM
JoeNova's Avatar
JoeNova
Originally Posted by rbates74
The plan. Eventually. Is twincharging. Two turbos feeding the m90 should hit 600rwhp. But thats down the road.
Oh. And i bought that whole motor minus the 1.8 rockers for $500. Just had to add rockers and a valvejob. Even had new gaskets.
For what its worth, I've messed with twin charging before. Extremely lackluster results for the effort involved. Its extremely cool though.
The setup made over 1000whp but took 40+ PSI to do it, feeding a blower with twins. Removed the blower, and it picked up a few horsepower on 20 less PSI with just the twins.
Old May 16, 2019 | 11:10 AM
rbates74's Avatar
rbates74
The point of twincharging (for me) is simply to eliminate lag and bring the power on down low. For "all out power" simple turbo is the way to go.
Old May 16, 2019 | 11:12 AM
rbates74's Avatar
rbates74
Leroy is a big budget big name ls swapped monster. My poorvette is named Fiona. She used to be a princes, now she's an Ogre, and she likes it that way.
Old May 16, 2019 | 11:14 AM
rbates74's Avatar
rbates74
Oh yes. The poor corvette being abused. The alternitive was selling the suspension and scrapping the rest. C4 Corvette frames arent worth a whole lot.
Old May 16, 2019 | 11:25 AM
pologreen1's Avatar
pologreen1
Hmm. Let us begin class.
1. I sold my heads for more than what I spent on that swap.
2. That motor has 50 more HP than my 383 TPI
3. 3800 weighs 100 lbs less than a 350.
4. 3800 (block) sits 2 inches lower than a 350
5. The 2 missing pistons mean the 3800 sits 6 inches further back in the chassis.
So, what you are missing is intelect, tact, and basic knowledge of physics.
Is there a part of cheaper, lighter, lower, more powerful and more centered that is dificult to understand?
In fact, is there even one actual negative besides predudice that you can come up with?
Be more careful in your judgements as they may say more about you than your target.
No hood...
No fenders..
Frame, tires, suspension, motor, trans, cage. Send It!
400+ RWHP, 2200 or so pounds, 50/50 weight ratio, 12 inch wide z06 rubber. Want to race?
Sounds fun for a track rat, but if you think that hunk will fly on the street... I doubt it. You are further ahead to make a cart. That will draw some very unwanted attention looking like that.
With the "wanna race" attitude you'll find a match real quick.
One thing you are forgetting.... The car was never built for that. It will be fun until you realize what you have. My guess is a car in the ditch that has been dismantlement.
For your safety I'll spout my opinion.
1.You have way more power than the car was engineered for
2. It's a turd
3.It's an old C4
4. All of these combined might prove that lack of weight will make it fun, but only scary fun not in control fun.
Seriously though. You better redo the whole car. Dropping power in to an old c4 is a bad idea without a fully supporting build. A miata is more competent with the same hp.
Some of us here make more than 2x your power in a c4, even at your power level the car is needing some work even for a good driver, just plain dangerous with old or even stock suspension period at those weight levels.
if you are copying Cleetus and all the guys before him, consider their builds. Enjoy it and good luck should be a ripper.
Old May 16, 2019 | 12:02 PM
rbates74's Avatar
rbates74
I have a modular pulley system. So I can run anywhere from 8 to 18 psi with a half an hour swap.
The cage, harness and additiinal bracing are on the way.
Ive been building toward this since 2013 when my vette got wrecked. Prior plan was to do the same thing with a 383 to 421 smallblock, but finances kept pushing it back.
Coil overs are probably in my future. You are corect that I have more potential power on tap than I can use, and are the first person to come to that conclusion on their own. Usually its comentz about me ruining the car with a v6.
Plan is to lighten it as much as possible and then add weight near the "bumper brackets" to even it out.
I will be keeping more of the body than most vetteKart guys and will be heavier. Between 2200 and 2600 depending on "what it likes"
It is pretty much a track rat, but will be road legal and run on the 3.4 pulley with a street tune most of the time.
Safety is a key priority. But I need the engine in to do the mock up for the cage. Some guys could draw it on paper, but i need to put it together and take it apart a few times.
Old May 16, 2019 | 12:04 PM
DGXR's Avatar
DGXR
Now THAT is a real project car.
Old May 16, 2019 | 12:06 PM
JoeNova's Avatar
JoeNova
The cage and additiinal bracing are on the way.
Motorcycle coilovers for something that light. I have them on mine. $150 will score you a full set with some patience.
Old May 16, 2019 | 12:20 PM
  #33
rbates74's Avatar
rbates74
This set is almost brand new and the mustang they are on is too heavy. When he swaps them out they are mine... If they work for me or not is anouther question. There is also a dual shock per axle coil over set up on a jaguar that may fit. Just have not lucked into a good pair.
Old May 16, 2019 | 12:28 PM
  #34
JoeNova's Avatar
JoeNova
I used sport bikes coilovers on mine, grabbed all 4 on ebay for $35/each. Double adjustable with reservoirs, and they were basically a bolt-in deal with a couple exceptions.
1. I have to move the tops of the rears forward a few inches so the reservoirs cleared the axles.
2. I had to bolt the lower of the fronts to the sway bar mounting hole on the front lower control arms and trim a couple of pieces of the frame, again all because of the reservoirs.
Get ones with parallel reservoirs, all issues solved.
Old May 16, 2019 | 12:37 PM
  #35
JasonAndrew's Avatar
JasonAndrew
No hood...
No fenders..
No bumpers and it ain't street legal.
Old May 16, 2019 | 12:41 PM
  #36
rbates74's Avatar
rbates74
Why would you drive it anywhere without bumpers?
Factory bumpers are still here. But they will be replaced with safer upgrades.
Have you ever looked at the actual bumper on a c4?
Cheap thin stamped steel. Frame is pretty beefy but the only crumple zone is the plastic bumper cover insert.
Old May 16, 2019 | 12:51 PM
  #37
rbates74's Avatar
rbates74
Screenshotted for future reference.
To Poorvette
Old May 16, 2019 | 01:02 PM
  #38
JoeNova's Avatar
JoeNova
I used Kawasaki ZX-10R coilovers on mine. The reservoirs are offset to the side and forward. You can see the bend of this picture.
That forward offset is the only issue. The shocks come with an attachment on the top with an M16 stud on it. The top perch on the factory C4 rear shocks threads directly onto this, making the rear shocks 100% bolt-in.
The problem is that the foward offset causes the driver's side axle to hit the reservoir. Thats why I moved my upper mounting hole forward a few inches.
For the front, it hits the little hump on the lower control arm where the sway bar mounts.
I could have made a bracket to raise it up high enough to clear, but then the spring would hit the upper control arm just a touch, so I moved it forward and mounted the bottom of the coilover to the sway bar hole (they are the exact same size hole). This required me to trim some of the gussets on the frame with a cutoff wheel to clear the reservoirs. Just like the rear, the M16 stud on top of the coilovers bolted directly into the upper shock mounting hole using the factory rubber grommet and an M16 nut.
Parallel reservoir shocks would have been PERFECT.
Old May 16, 2019 | 01:41 PM
  #39
bb62's Avatar
bb62
I think when some people see C4s being cut up and modified, especially with engines like a V6, they tend to believe that such modifications devalue the brand and drive the very low impression that many people have of C4s in general. It's a bit of chicken and egg, the more people cut the cars up, the less value they have and the less value the cars have, the more people cut them up. Imagine someone with a Ferrari 275 GTB dropping in a modern Alfa Romeo engine and tossing the V12. Is it even a Ferrari anymore? How would those brand loyalists view that car?
I suppose many Americans view matters differently given the history of mass production in the country and the concept of liberty and private property. So many were produced that the incremental car modified does not really take from the whole and since it is your property, you can do with it as you please.
This dichotomy is always going to be present, but you will tend to see the former more at a site like this given the love for the vehicle essentially as it was produced. Good luck with your build.
Old May 16, 2019 | 01:54 PM
  #40
JoeNova's Avatar
JoeNova
Sounds like people need to learn to mentally separate racers from collectors. A C4 being modified into a race car isn't anymore of a C4 than one cut into a kart. Maybe even less so, since we are more likely to retain what mechanically made it a corvette to begin with. Yet somehow the purists here don't seem to have an issue with people swapping big blocks into their C4s, or converting them to carbureted, or tuning one into a tube chassis, etc. As soon as the body comes off, its up in arms.
Makes me want to cut up another crusher-bound C4.
