Steering column
Old Jan 12, 2020 | 06:50 PM
mad80's Avatar
mad80
2nd Gear
Default Steering column
Is there a possible way to eliminate the telescoping steering column or is there a replacement column out there without it?
Old Jan 12, 2020 | 08:25 PM
WVZR-1's Avatar
WVZR-1
Very dependent upon your issues you could 'lock it'. What issues do you have?
Old Jan 13, 2020 | 01:56 AM
Hot Rod Roy's Avatar
Hot Rod Roy
I'm going to guess that you're having trouble with the steering wheel moving in and out. That's easily fixable!
Disconnect battery.
Carefully pry off the horn button, then disconnect the horn wire from the bottom of the horn button.
With the lock lever pushed to the far right, remove the two screws in the center of the lock lever that attach the lever to the "star nut".
Re-position the lock lever CCW to the next pair of screw holes on the lock lever.
Replace the two screws.
Test: Does the steering column lock properly? If not, repeat this procedure to the next pair of screw holes. There are lots of combinations of screw holes and "star nut" slots to adjust to your liking! The column should be locked with the lever pushed to the far right!
Old May 23, 2020 | 09:28 AM
mad80's Avatar
mad80
2nd Gear
I have to change my ignition switch and wanted to change my steering wheel to something else while I was at it.
Old May 23, 2020 | 11:23 AM
WVZR-1's Avatar
WVZR-1
There are various hubs/adapters that allow a change and also retain Tilt/Travel. A steering wheel change ain't always a very pleasant experience.
Old May 24, 2020 | 09:02 AM
RWDsmoke's Avatar
RWDsmoke
You could use an allen head set screw in place of the locking screw. You can still adjust it but you will have to pop the horn button and use an allen wrench.
To Steering column
