My 84 project
Old May 3, 2020 | 09:14 AM
  #201
84 4+3's Avatar
84 4+3
So that seems to have mediated the problem but... now it feels spongy at part throttle. Go figure.
Old May 3, 2020 | 10:42 AM
  #202
GregMartin's Avatar
GregMartin
A day on the dyno will sort it out
Old May 3, 2020 | 03:02 PM
  #203
84 4+3's Avatar
84 4+3
East coast has a dynapack load bearing one.. I think ill try to rent(if they do it) it because those are pretty trick.
Old May 3, 2020 | 07:19 PM
  #204
GregMartin's Avatar
GregMartin
Yeah that’s the go.
Old May 5, 2020 | 07:40 AM
  #205
84 4+3's Avatar
84 4+3
So how should I go about repairing my gas pedal mount...
Old May 5, 2020 | 08:52 AM
  #206
mazdaverx7's Avatar
mazdaverx7
You replace the entire pedal assembly. My friend and I were making the mounts about 10 years ago and selling them. We machined all of the pieces and used oillite bushings for longevity. We stopped making them because the labor and parts were more than the asking price we had. And we didn't want to charge someone much more than an entire pedal assembly which can be had for less than $100.
Old May 5, 2020 | 10:20 AM
  #207
GregMartin's Avatar
GregMartin
Well I guess the choices are buy an aftermarket one with a plastic mount, after all the last one lasted 36 years. Or get @mazdaverx7 to make you one and pay the costs. If you choose option B I’ll get one too.
Edit: I think it’s just two 10 mm nuts and disconnect the cable. I think I’d disconnect the cable at the TBI end first to get a bit of slack.
Old May 6, 2020 | 06:45 AM
  #208
mazdaverx7's Avatar
mazdaverx7
To be honest we've had quite a bit of intrest over the years for these brackets. I've talked to my buddy that owns the equipment and he has been skeptical about making them since again. If I can convince him to let me run the lathe and weld them up I'll order some bushings again and see if i can make some. The original we made is in my 84. We made it for that car back in 2009 and it's working perfectly to this day. I'll see what I can do. I do remember that they were difficult to make and the material cost wasn't cheap due to the stainless steel and bushings we used. That's likely my friend's holdup.
Old May 6, 2020 | 07:10 AM
  #209
GregMartin's Avatar
GregMartin
Let me know I’ll buy one if you make one. Alternatively I have a little lathe, drill press, mig and arc welder etc in my shed so if you shared the drawings I could make my own. Anyway your call.
Old May 6, 2020 | 09:31 PM
  #210
Gibbles's Avatar
Gibbles
My pedal mount broke when i first got my car.
i found it had neen glued at one point.
i found a billet aluminum piece on ebay at the time and grabbed it.
I don't see it for sale any longer...
Old May 10, 2020 | 04:49 PM
  #211
84 4+3's Avatar
84 4+3
Here's a fun question. What do you suppose the RPM ceiling is on a stock HEI with fresh oem components.
Old May 11, 2020 | 08:54 AM
  #212
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Not 100% on rpm limit of the distributor, but I would venture to say that it is north of 7500. I think the limiting factor will be the coil, which probably won't go 7500, but maybe it will. The highest I have ever had mine was 6300 and worked just fine. Back in the day on a 69 Z28 302 with a Malory dual point, I missed 2nd gear of all gears and normally shifted at 8K when racing. When I missed 2nd, I watched the big SUN tach bounce off of 10K. It was still running just fine at 10K. This motor wasn't stock either and ran like a scalded dog.
Old May 11, 2020 | 04:11 PM
  #213
84 4+3's Avatar
84 4+3
Good to know. All I know is that I hit a rpm threshold and afr just tanks rich... around 6000 rpms being honest. The table leading up to that point is pretty flat as far as fueling though so I'm not exactly sure what is going on there.
Old May 11, 2020 | 05:59 PM
  #214
GregMartin's Avatar
GregMartin
You know some time on a load cell Dyno will reveal all.
Old May 11, 2020 | 08:59 PM
  #215
84 4+3's Avatar
84 4+3
yes well at 500$ I can spend that much better elsewhere...
Old May 11, 2020 | 09:59 PM
  #216
GregMartin's Avatar
GregMartin
Yeah but it is money well spent, provided you have a good tuner or the time to get it right yourself. But I get it
Old May 11, 2020 | 10:51 PM
  #217
84 4+3's Avatar
84 4+3
I have yet to find someone who'll touch it sadly. Everyone wants HP tuners. If I was full time right now and not in quarantine I'd do it but... the other thing is that it seems a waste to do it now only to slap on a renegade hopefully and then do it all over again...
To My 84 project
Old May 12, 2020 | 12:09 AM
  #218
GregMartin's Avatar
GregMartin
Yeah well that’s true and the Renegade seams tantalizingly close. It frustrates me when you get the supposed timers who can only use one type of ECU or ECU software. We recently tuned a little bmw M44s. We replaced the factory ECU with a Haltech E8, they are only a couple of hundred bucks but the software is pretty old and you have to use injector pulse width instead of VE so lots of people won’t do it any more. We hired out a dyno did it our selves. Car runs great.
Old May 17, 2020 | 11:17 AM
  #219
84 4+3's Avatar
84 4+3
taking a chance with crazy glue and some jb weld so I can at least drive it. Clean enough break it'll work until I have a permanent solution.
Old May 17, 2020 | 11:59 AM
  #220
84 4+3's Avatar
84 4+3
Little extra protection to be safe.
