My 84 project
Old Jun 7, 2020 | 10:41 AM
  #241
GregMartin's Avatar
GregMartin
Sounds promising. I have my tune set to pull timing first and cut fuel second.
Old Jun 7, 2020 | 11:12 AM
  #242
84 4+3's Avatar
84 4+3
That seems about right. I looked at the tune and the difference between the two is like 150 rpms so not a huge thing to notice. But I definitely hit it.
Old Jun 7, 2020 | 06:52 PM
  #243
GregMartin's Avatar
GregMartin
Yeah pull timing for over exuberant driving and cut fuel for missed gear shift, stuck throttle, etc.
Old Jun 7, 2020 | 08:36 PM
  #244
84 4+3's Avatar
84 4+3
I've had the stuck throttle before lol. Way before any work happened though.
Old Jun 11, 2020 | 09:00 PM
  #245
84 4+3's Avatar
84 4+3
Part throttle response seems to be hammered out. Still won't break traction which I guess I'm okay with.
Old Jun 12, 2020 | 03:18 AM
  #246
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Were you in 3rd at 45? Mine would have downshifted instantly into 2nd at 45 and take off like someone kicked it in the ***. Sounds good though and responsive.
Old Jun 12, 2020 | 04:02 AM
  #247
GregMartin's Avatar
GregMartin
I’m with Tom on this one snap it back to second and thump it.
Old Jun 12, 2020 | 05:38 AM
  #248
84 4+3's Avatar
84 4+3
Nah that's second. I went to floor and right back off and you can tell by how much I moved around that I wasn't expecting that lol. Guy was only 30 in front of me so I slowed down to get some room. Its getting uncomfortable to tune safely on the street now...
Old Jun 13, 2020 | 10:08 AM
  #249
84 4+3's Avatar
84 4+3
I've sourced some dyno time at ECS. I'll be doing the tuning myself but am able to use the load bearing dyno.
Now if only I had a ported manifold...
Old Jun 13, 2020 | 10:34 AM
  #250
GregMartin's Avatar
GregMartin
That’s great news. You should be able to get it running nicely. There will be other dyno days when you get that Renegade.
Old Jun 13, 2020 | 11:10 AM
  #251
84 4+3's Avatar
84 4+3
yea. 150 for 3 pulls and he'll give me time to make whatever adjustments I need.. seems reasonable to me. I'll do it in a few weeks when I have everything close. See here.
Old Jun 13, 2020 | 07:55 PM
  #252
GregMartin's Avatar
GregMartin
Will he hang around and help you? I found that when we tuned our racing BMW recently the guy vas very helpful. He basically left us to it but would give you some tips which made the whole process much quicker and easier. A lot of the time the problem is the guys aren’t familiar with the ECU/tunning software so don’t want to commit, but they do know how to tune if you drive the software. With our BMW the guy knew the old Haltechs well so gave us some good tips. Later in the day we put my corvette on the dyno and he was interested in the EBL software (he said it looked exactly the same as something else but I can’t remember what he said) and of course TunerPro was obvious to him. He ended up jumping in the driver seat and just getting me to drive the software from the passenger seat. It was quick and efficient. Next time we do dyno work I’ll make sure we pay for some of his time because that’s the quickest and easiest and you are more likely to get good results.
Old Jun 14, 2020 | 12:56 AM
  #253
84 4+3's Avatar
84 4+3
I mean tuner pro resembles HP tuners to a point so I would imagine anyone would knowledge on that would understand it.
Old Jun 14, 2020 | 01:15 AM
  #254
GregMartin's Avatar
GregMartin
Yeah absolutely. If you can get him to help To do the pulls and you change the computer under his recommendations your day will go much smoother.
Old Jun 16, 2020 | 11:43 AM
  #255
84 4+3's Avatar
84 4+3
Toasty.
Old Jun 16, 2020 | 02:30 PM
  #256
GregMartin's Avatar
GregMartin
It that during the dyno pull
Old Jun 16, 2020 | 02:38 PM
  #257
84 4+3's Avatar
84 4+3
thats high idle warming up. AFR reading was 14:1 and timing 22 degrees... idk why it did that. I can 9nly imagine what they look like running around.
To My 84 project
Old Jun 16, 2020 | 02:43 PM
  #258
GregMartin's Avatar
GregMartin
Like -10 Deg and 17 AFR
Old Jun 16, 2020 | 03:42 PM
  #259
84 4+3's Avatar
84 4+3
What do you mean?
Old Jun 17, 2020 | 08:06 AM
  #260
GregMartin's Avatar
GregMartin
What do you mean?
yeah sorry I was posting at 4:30am so still a bit sleepy. What I meant was you would think that the timing was retarded or the engine was lean to get the pipes to glow cherry red at fast idle.
