Eliminate or Aftermarket Mufflers?
Old 10-08-2020, 09:27 PM
aklim
aklim's Avatar
Received 2,285 Likes on 1,988 Posts
Of course they like it. It's loud. Loud is good. I know the kids like my Borla and the wife hated it. I think she's glad it was destroyed and the Corsa is quite a bit better, noise wise. Now she is willing to ride with me in it.
Little Red L98 (10-08-2020)
Old 10-08-2020, 09:29 PM
WydGlydJim
WydGlydJim's Avatar
It's not a ZR-1 scrap it...........
I'm joking alright!
Little Red L98 (10-09-2020)
Old 10-08-2020, 09:31 PM
aklim
aklim's Avatar
I'm joking alright!
Only when the motor fails. That is a big ticket item that hits the line.
Old 10-08-2020, 10:30 PM
ACMX92
ACMX92's Avatar
2021 C4 of the Year Finalist - Modified
Originally Posted by Little Red L98
Cost is a factor. I’m not necessarily cheap but I am frugal. And I know what I want - a decent sound, louder than stock, that’s still quiet when I’m cruising along. It ain’t a hot rod but it can sound like one when I stomp on the gas.
I saw something like this but with an H pipe. With no cat or mufflers it might be too loud or not have enough back pressure. Speed shop dude will know. He sounded excited about the prospect.
I have that exact same exhaust with a set of dual working outlet reproduction mufflers. It is plenty loud and actually has a bunch of drone below 2000 rpm. I think the drone is either due to the lack of a crossover or the fact that both muffler tips are open and causing some sort of resonance.
I went with this exhaust simply because it was the cheapest setup out there. I'd really like to go with a pypes setup in the future.
Old 10-09-2020, 10:17 AM
CarLover014
CarLover014's Avatar
If you plan on going with muffler eliminators, head to an exhaust shop and have them cut out the mufflers and weld in a pipe in the mufflers' place. It should take maybe an hour, tops. I had it done to my 1996 for $75 including them welding the LT1 tips on the new pipe as well.
95AQUAMET (10-12-2020)
Old 10-09-2020, 11:37 AM
3D-Aircrew
Support Corvetteforum!
3D-Aircrew's Avatar
I had muffler elliminators on my car and decided to replace the front y pipe with the mini cat eliminators so I still had a big cat in the middle. Sounded way to loud ... I couldn't live with it so I put on stock mufflers and now it's much better. If you care about your neighbors, go with mufflers.
Old 10-09-2020, 05:05 PM
Little Red L98
Goon Squad BS Detector
Little Red L98's Avatar
2018 C4 of the Year Winner
2017 C4 of the Year Finalist
St. Jude Donor '15, '17
Pipes are rusted from cat back. Mufflers are ok. I’ll get it on a lift next week to check it all out and see what truly needs replaced. Cat elimination will throw a code setting off the annoying check engine light but it will run fine. Might end up keeping it. I don’t know yet.
I want this to be a one and done proposition, not buy/install something, find out I don’t like it then buy/install again. Not too worried about neighbors. I’m respectful enough not to gun it in the hood and I never speed in my own neighborhood.
3D-Aircrew (10-13-2020)
Old 10-09-2020, 07:51 PM
aklim
aklim's Avatar
Running fine just means you notice nothing and NOT that nothing is wrong. It will compensate until it can't. Also, you have one check engine light and 5000 other things that can be bad. Fill up the space with the Cat removal and you won't know of anything until it is really bad. I'd either get O2 Sims or get it programmed out.
Hard to say since I know I hate my Borla because of the noise and prefer the Corsa because of it being more quiet.
Old 10-09-2020, 10:27 PM
9T3VETTE
9T3VETTE's Avatar
I’m told it will run lean if the exhaust flows too freely unless it’s tuned to compensate. Makes sense. I plan on removing the cat so the only restriction is the stock manifold. I’m just a casual gearhead so I’ll defer to the speed shop experts.
Less back pressure is better, however there is a risk on speed density engine management systems. Large changes in back pressure (eg going from a stock setup to cutouts) can change the volumetric efficiency of the engine (easier to breathe = raised VE). The PCM does not know this change and delivers what is assumed the correct fuel amount based on MAP, potentially leading to a lean condition. Obviously, this is one reason MAF based systems respond better to mods as they read air amount directly and could detect the VE change.
Old 10-09-2020, 10:57 PM
Little Red L98
I don’t know where I’m going yet but this is a good discussion. Muchas gracias.
Old 10-10-2020, 05:35 PM
Incorvettei
Incorvettei's Avatar
Have a corsa system on my 86. Nice sound at normal driving, no drone on the highway and when I boot it the exhaust sounds great
Quick Reply: Eliminate or Aftermarket Mufflers?
