88 ABS pump??
Old May 1, 2021 | 12:04 PM
14RANDY's Avatar
14RANDY
Default 88 ABS pump??
Working on an 88. Been loosing brake fluid. But it finally spilled out the well where the ABS pump/valve is. The well was full of Water and brake fluid! After I disassembled, found 1 line completely rotted through! The “relief” hole is more than 1/2 way up the well, do you think I can drill another hole lower, so it won’t fill up again?
Old May 2, 2021 | 07:08 AM
DWAVette's Avatar
DWAVette
Did you figure out where the water is getting in there from?
Is the constant water what rusted the line and caused the brake fluid leak?
I would want to be sure to solve the initial problem prior to making accommodations for it.
