Dash light issues
Old Aug 5, 2021 | 11:44 PM
CE_Vetteboy's Avatar
CE_Vetteboy
Default Dash light issues
1996 Coupe. I don’t have lights on any buttons or switches when my headlights are on. The dimmer does change the brightness of the instrument cluster and radio/HVAC and the interior lights come on if I slide it all the way up.
Old Aug 6, 2021 | 09:19 AM
CE_Vetteboy
Any suggestions? I sold my FSM after I sold my first ‘96. I have another one coming but haven’t received it yet.
Old Aug 7, 2021 | 07:09 AM
CE_Vetteboy
Checked all the fuses they all look fine. I searched the forum and google but this seems to be an unusual problem as I’ve found nothing that resembles the same issue. Could the photocell on the dash have any influence?
Old Aug 7, 2021 | 11:41 AM
CE_Vetteboy
Using the paper clip method I checked the CCM for codes (none) and tested the dimmer circuit including the ambient sensor involvement, all seems to be functional. I tested the courtesy light output, I can hear the relay and the interior lights turn on and off. The problem is I isolated to the LED side of the lighting circuit as all of the incandescent lights work but none of the LED’s (buttons, switches, power window switch and lock illumination,etc) are working. Since my FSM hasn’t arrived yet I found a few diagrams of the dash wiring on here. I would like to test the incandescent power driver as I do not have power to the three fuses (RH ILLUM, LH ILLUM and CNSL ILLUM) anyone know where this module is located?
Old Aug 7, 2021 | 07:12 PM
CE_Vetteboy
A deep dive produced this thread:
https://www.corvetteforum.com/forums...em-solved.html
I’ll pull the dash apart and test this circuit tomorrow.
Old Aug 7, 2021 | 09:40 PM
CE_Vetteboy
Well I couldn’t wait until tomorrow it was bugging me so I tore into it. Located the module and tested it as per the thread I attached in my last post. Sure enough I had reference voltage, input voltage but nothing on the output. I removed the module and placed a jumper between the reference and output wires and bingo! We have lights.
Old Aug 10, 2021 | 09:04 PM
Goldcylon's Avatar
Goldcylon
I reported on this in 2007. Glad you figured it out. GC
(https://www.corvetteforum.com/forums...-are-gone.html)
Old Aug 10, 2021 | 11:20 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Originally Posted by CE_Vetteboy
We have lights.
Good work. I'm glad you were able to figure this out
Old Aug 11, 2021 | 06:58 AM
mazdaverx7's Avatar
mazdaverx7
Nice job! This could come in handy for others with the same issue that are searching the forum!
Old Aug 11, 2021 | 04:11 PM
CE_Vetteboy
Strange your thread never came up when I searched, especially with Google. It is certainly a tight place to work in!
Old Aug 14, 2021 | 09:29 PM
CE_Vetteboy
Well, I installed the replacement module (non-GM) and it did not work. Testing the output gave me 0.0 Volts right out of the box.
Again, if I jumper 12v to the output wires, all of the lights work. This tells me everything downstream of the module is good (grounds, etc).
I have now ordered a new Delco unit and will report my findings once I have it.
Old Aug 15, 2021 | 01:20 PM
mazdaverx7's Avatar
mazdaverx7
Sometimes the aftermarket electronics do not work well in our cars. I can't tell you why but it really seems to be hit or miss. Keep us updated on how things turn out!
Old Aug 22, 2021 | 09:14 PM
CE_Vetteboy
Well the new part showed up in a Delco box but it was the same Mexican ‘Mallory’ part inside. Fortunately it works. Let’s call this one closed.
Old Aug 23, 2021 | 06:47 AM
mazdaverx7's Avatar
mazdaverx7
Glad to hear that its back up and working properly! Shame that its a made in Mexico part in a Delco box. Part of the reason I loved these cars so much was because their replacement parts were made in the U.S. Now it seems there's more and more outsourcing going on. At the end of the day it works and hopefully will give you no similar trouble in the future.
Old Apr 2, 2024 | 06:41 PM
Carmen1957's Avatar
Carmen1957
3rd Gear
Default Same Issue
Where is the module located under the dash, by steering column?
To Dash light issues
