Dash noise
Old Mar 15, 2022 | 06:24 PM
Idaho Mark's Avatar
Idaho Mark
Default Dash noise
Just got a C4 for my collection 1996. Everything is in top shape but the lower part of the plastic vents on the dash at the passenger's side make a lot of noise rubbing on the dash. I could put something under the plastic vents between them and the dash to make it go away. But there has to be a better way on a car with less than 20k miles. Anyone had this come up or know a cure?
Old Mar 15, 2022 | 06:34 PM
Whaleman's Avatar
Whaleman
My 96 center dash vent also made noise. I removed the bolts and the vent. I then glued a thin rubber washer to the back side of each screw hole and installed it with the screws tight and the noise completely stopped. Dan
Old Mar 15, 2022 | 10:15 PM
Idaho Mark's Avatar
Idaho Mark
Thanks for that Dan and I'll keep that in mind. My large plastic vent part only has 2 torque screws but something else holds it in place. If I figure hoe to get it out I will likely put a thin amount of rubber silicone on it to separate it from the dash. Thanks for the idea.
Old Mar 16, 2022 | 02:06 AM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
I don't know if it's germane to your dash rattle or whatever it is, but I basically pulled al of the interior and added felt washers to all of the screws.
Ever since I did that, I get a rattle every once in a while, but not very often.
To Dash noise
