hatch problem
Old May 15, 2022 | 10:37 PM
Reneh's Avatar
Reneh
6th Gear
Default hatch problem
So i’m trying to bring my grandpas 96 c4 back to life, i’ve noticed when i went to open the hatch the center console button doesn’t work but the drivers door does. after reading around on the forms people are having the opposite problem any ideas?
Old May 16, 2022 | 03:14 AM
Reneh's Avatar
Reneh
6th Gear
it’s the automatic which i believe is a 4 speed, any other ideas
Old May 16, 2022 | 07:54 AM
pedricd's Avatar
pedricd
Someone removed the trim and that button is unplugged? You should be able to remove the button to see if the wires are still hooked to it. I believe it twists then comes out. If it is plugged in you can test the button and clean up the connections if corroded.
other option to access is to remove the trim…I don’t have an auto but I believe removing the trim you have to be careful with the shifter/needle…
If it all checks out and still doesn’t work then you may have a broken or damaged wire somewhere and would need to test and trace.
A Factory Service Manual (FSM) is very useful and you should acquire one if you do not have one yet.
Old May 16, 2022 | 08:06 AM
FostersPerformance's Avatar
FostersPerformance
If you can get to the 2 wires at the console button, jump them together and see if the hatch opens.
Old May 16, 2022 | 04:08 PM
RUU's Avatar
RUU
Originally Posted by ihatebarkingdogs
If it is a 6-speed car, the parking brake needs to be applied for the console button to open the hatch.
Interesting, my '96 does not require the parking brake to be engaged for either of the hatch release buttons to work. Wonder if a previous owner bypassed that.
Pretty sure there are 2 tabs on the backside of the button that need to be squeezed to remove it. The lighter socket is threaded on, but again, needs to be unscrewed from the back.
Old May 16, 2022 | 04:30 PM
pedricd's Avatar
pedricd
Mine does not require parking brake either...at least with the engine off.
On the button, I am going off of memory. I just had the console out due to my stereo work and clutch replacement, and the button literally fell out...I thought I remember it loosely going in then twisting to lock...removing the console would be safest rather than breaking something though
Old May 16, 2022 | 09:28 PM
jmeyer58's Avatar
jmeyer58
Here’s the wiring diagram
Old May 16, 2022 | 11:27 PM
pedricd's Avatar
pedricd
Door release only works with the door open.
If you have a 6-speed 96, have you ever actually tried the console button with the brake off?
Look at the wiring diagram. Please tell me how the console button can operate without the park brake set? (Or an automatic in P or N.)
Engine on, off, has nothing to do with the console button.
If you have a 6-speed,have you actually tried the console button with the brake off?
You look at the wiring diagram too. The console button can not function without the park brake applied, or the automatic in P or N.
This comes up frequently.. The cars are wired as shown in the diagram. But every time it comes up, there are peeps that say that's not how their car works. Go try it. Then please be humble enough to admit that you were mistaken, once you see that the park brake has to be applied for the CONSOLE button to work. (Not the door switch(s)). Or P or N for an automatic.
Absolutely… My car in the garage is just in gear, no parking brake. I can pop the hatch with either switch no issue…. I just did it, right now. However, this is a 93…
Old May 16, 2022 | 11:48 PM
RUU's Avatar
RUU
Tried it before my first post in this thread.
From the owners manual,
If you have a manual transmission, you must set the parking brake before you can use the switch when the vehicle is running.
The humble pie is all yours. Enjoy. ​​​​​​​
Old May 17, 2022 | 07:59 AM
jmeyer58's Avatar
jmeyer58
My ‘96 works just as depicted in the wiring diagram (A4)
To hatch problem
