MOATES Officially Closed
1 x 'Ostrich 2.0 : The New Breed' (OSTRICH_2)
1 x GP1 Package: GM Adapter with 2 chips (GP1)
1 x 'BURN2 Chip Programmer' (BURN2)
1 x EMUC2806 Emulation Cable 28-pin 6-inch (EMUC2806)
My question is, is there anything I should find and download NOW (while I can find it) like drivers, software, ect? So that when I am ready to begin my tuning journey in a few months I'll be able to? The installation guides on their website are gone now. Not sure what I should do to prepare for the future without them.
If anyone can point me to the software I should get I would sincerely appreciate it!
LT1pcmtuning.com
This site has a bunch of info and links to tuning forums. I personally download tunerpro to use for my tuning. I bought the same things you did. So far I got as far as data logging my car. Once you download tunerpro there are specific files you need to load into your tunerpro to make it work with your year/configuration car.
With extra chips, that's not a problem BUT....If the adapter fails, you might not be able to find another adapter to burn and plug in those chips. That could lead to the need for a new ECM -- at the tune of $500 (pardon the pun)! So, I went on eBay and found/bought an extra adapter. It's kinda like learning you might never be able to buy a replacement ECM (new or used) if the computer to your car goes bad. (Sure, you could buy a new ECM conversion, relearn how to program THAT, and be back in biz. But, why depend on one piece lasting the entire time you own the car?)
Long story short: Once you install an aftermarket adapter and chip, I'd want to make sure you can fix it if it breaks. That's why I weighed the POTENTIAL option of buying a $500+ programmable ECM vs an extra $50 adapter now.
EDIT: There's also the possibility of a wideband sensor. I never bought one and I'm not sure Moates was a source anyway. I got away with tuning my w/o one (using dyno readings and O2 counts in scans). It takes tons of time to do it that way and you have to get a bit lucky. The better way is using a Wideband. I suspect it pays for itself by saving you hours looking at your scans.
That is a good point. I was mainly concerned because I had never hooked it up before, and was worried I'd never be able to find the drivers for the Ostrich 2.0 or Burn2. But I found that I was able to find the drivers by using Wayback Machine. It's anyone's guess as to how long they'll still be on the Moates server.
Now if it breaks one day, then yeah I'd have to go to an aftermarket ECU or find one on the used market as you suggested.
It's a good wake up call though. As these cars get older and older we might not always be able to find the parts we need.
I'm not saying more modern tuning equipment is bad! BUT, if you're going to invest your time/learning to "reprogram" the stock ECM to use the Moates adapter/chip, I'm suggesting you MIGHT wanna buy an extra adapter now. Mine should add be here in a day/two. I'll test right away to make sure they are compatible with the Moates adapter. (That means I'll transfer the PROM and programmed chip to see if the car runs the same).
Maybe some other website still offers the adapters? I don't know. But, there is a guy selling them on eBay. They have couple of minor asthetic differences but the circuit boards are reportedly the same. That's why I plan to test and report back....unless it's sealed. If so, I might leave it that way in order to resell it someday and "NIB" or "NOS". (They have more listed under "GM mem/cal PROM ZIF socket")
Example: If you don't know what a Burn2 is...or Zif Socket Prom Adapter....or whatever.
My goal is to just have a cable tucked up under the dash that can be plugged into a laptop running appropriate software and that can flash and reflash easily, that way avoiding opening up the dash and swapping a chip each time a new tune wants to be tried.
or your looking for a emulator like pocket romulator. The bad if the battery of the device dies your dead in the water.
FWIW, I left my ECM lying on the passenger floor for months while trying and retrying tuning changes (to learn how everything worked). If you did that, changing chips is very easy. I can burn (or reburn) a chip AND install it in 2 minutes. And, that allows time to grab a Coke! LOL You pop two little plastic levers and the board (pictured above) pops out. With the board (pictured above), you'd do the same, pop a lever - to release and swap the chip. Then plug the board back into the ECM. Its get's very easy after a few iterations. So....you COULD buy a BURN2 with ODB1 cable and be golden. This is how it would work....
Drive around and observe changes desired.
Pull over, pop chip from ECM, make changes in TunerPro, burn chip (using BURN2), reinstall, and repeat
The only difference with an Ostrich is you'd pull over, make changes, and drive. So....that $300ish (for an Ostrich) eliminated the need to pull, burn, and reinstall a chip. In all seriousness, it really doesn't take that long. Plus, I don't know that you could mount the ECM with an Ostrich. Even with that tool, the ECM probably needs to sit on the floor. I don't think the ribbon cable would fit through/around the ECM mounting cover.
Note: These statements pertain to an 89 car. There may be differences I'm unaware of on other years.
If I was building another pre-LT1 C4 I'd probably just go Holley.
-- Joe
https://boostednw.com/all-products
