Code 33, 34, 36 Fixed!
Old Feb 5, 2023 | 10:48 PM
Stoddard Garage's Avatar
Stoddard Garage
Default Code 33, 34, 36 Fixed!
1986 C4...
Took hours of debugging. Boils down to this TSB.
http://www.askatech.com/AskATechLive/AatFileShare/FastTrackReferences/fasttrack/us%20domestic%20driveability/g/g007.pdf
Make sure you buy the right part number relays (the power and burn off are different). I bought by cross referencing the part numbers in the bulletin at Rock Auto.
Note my MAF wasn't bad, but I replaced it before I found this TSB. The new "Cheapy" threw a code 36. Cleaned the old Boesch MAF with MAF cleaner and put it back on after replacing the 2 relays in the TSB above. All codes gone, prrs like a kitten.
Just put the exact relays from the TSB!!! Here's a screenshot but I recommend printing the .pdf and making sure you put the right relay with the right connector (look at the wire colors from the TSB).
Old Feb 6, 2023 | 10:02 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
thanks for this.
Old Feb 6, 2023 | 10:30 AM
Stoddard Garage
Originally Posted by VikingTrad3r
thanks for this.
You are welcome. Took way too many hours to figure it out. Another member posted the TSB but it was buried....I literally let it idle and listened to it for hours yesterday (on and off).
Good luck. Print the TSB!
Old Feb 6, 2023 | 01:46 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Originally Posted by Stoddard Garage
Another member posted the TSB but it was buried....Good luck. Print the TSB!
I posted a link to the GM TSB from my site over 10 years ago in this post, but yours has a bit more info and 87-270 seems to have been superseded according to yours.
Old Feb 6, 2023 | 01:54 PM
Stoddard Garage
I think your post is where I found the TSB originally! Thank you
To Code 33, 34, 36 Fixed!
