Corvette C4 92 Module 7 error
Old May 26, 2023 | 06:26 AM
Alan Alexis's Avatar
Alan Alexis
1st Gear
Default Corvette C4 92 Module 7 error
Hello, I just bought a Corvette C4 92, the car shows odo err in the cluster and when I make the obd1 port A-G jumper in the C12 display I have cleared the codes and module 7. It gets 7. Err, does anyone know what's going on?
Odo err Module 7. Err
Old May 26, 2023 | 08:14 AM
pedricd's Avatar
pedricd
Are you saying you cannot get the car to readout the current ODO/mileage?
I googled and it looks like module 7 was only on 96 model year…? Possible someone may have swapped out your CCM ?
FYI - If a CCM is replaced it has to be VIN matched/programmed to your VIN and the ODO set via a tech 1 within a certain set of miles (100) or the odometer will be permanently off…but that’s not an err message just a counting from 0 issue.
The CCM may be faulty… you could also try disconnecting the battery for 10-15 minutes and reattaching…just try.
Old Mar 25, 2024 | 09:57 AM
ZBrink's Avatar
ZBrink
St. Jude Donor '06
Hello, did you ever figure this out? My '90 is giving me the same for Err Module 7 but my display readout looks slightly different than yours. If you never figured it out, you might repost this in the Tech area.
To Corvette C4 92 Module 7 error
