Limp mode?
Old Jan 21, 2024 | 08:30 AM
Vettybetty1's Avatar
Vettybetty1
1st Gear
Default Limp mode?
Hello everyone,
my granpa gave me a 86 corvette if I could get it running, it sat for 10 years, I cleaned the tank, new sending unit, pump, fuel filter, oil change, battery, distributor cap, rotor, spark wires, and spark plugs.
it idles rough but my main issue is when I get about a 1/4 mile down the highway not sure if it goes into limp mode but it looses power and if you don’t let it idle it will bog down and turn off. After letting it sit for a couple minutes I can drive it another 1/4 mile, anything I should look into?
thanks!
Old Jan 21, 2024 | 12:04 PM
glbeauchamp's Avatar
glbeauchamp
Sounds like when it hits a certain temp it loses power and letting it sit it cools down and is good to go until it hits that temp again. I have no idea what it could be but I'd start with the thermostat and/ or temp sending unit. Or possibly the engine control module ( if there is one. Not too familiar with c4s) Good luck.
Old Jan 21, 2024 | 01:40 PM
Whaleman's Avatar
Whaleman
Your FIRST step is to check for codes. There are a lot of posts on here about how to check for codes with a paper clip. I find it way easier to use a 10 buck code reader. Dan
edit: Whatever is causing the car to go into limp mode I guarantee you HAS set a code.
Old Jan 21, 2024 | 02:28 PM
2011KLR's Avatar
2011KLR
See if the fuel tank is pulling a vaccum. The gas cap should be vented.
Old Jan 21, 2024 | 02:53 PM
CorvetteRules's Avatar
CorvetteRules
Check for codes. Since it only happens when warming could be something as simple as the CTS (coolant temperature sensor) causing too rich of a fuel mixture once to temperature.
Old Jan 21, 2024 | 07:17 PM
dburgjohn's Avatar
dburgjohn
Wondering if the O2 sensors are bad. Once warmed up they give feedback to computer to adjust fuel mixture. Also electrical parts from that era can fail with heat. It would be interesting to know if good spark is going to plugs when that happens. Old guys pull an easy plug wire, put a screw driver in it and hold next to engine while someone cranks to look at spark. There are tools for that, but when I was taught I was also poor lol.
Old Jan 21, 2024 | 07:38 PM
Whaleman's Avatar
Whaleman
There are many cases of the ICM working fine when cool and going to hell when hot. Dan
To Limp mode?
