C4 timing issue please help!
I just did the head gaskets on my 86 vert. All went smoothly until I screwed up the timing. I turned my engine over to tdc and then marked my distributor location in two spot before removing it. Now I went to reinstall it and can't get the marks to line up. I'm always within a quarter inch. Does this mean I'm one tooth off? After messing with it for a couple hours I said "screw it, I'm just gonna try to start her up!". Well of course, she doesn't start. Just turns over and every once in a while I get very light smoke out of the intake (any ideas why?). I tested for spark and I'm all good there. I also have new Bosch fuel injectors installed, so I'm really stuck. Any ideas? I would appreciate any help.
) . I'm really at a loss right now. I've done tons of research and fiddled with it for hours now. I've never timed an engine before, but I'm pretty handy so I thought could figure it out. Guess I was a little too optimistic.
it's ok if it doesn't seat all the way hits the oil pump due to the oil pump slot not being lined up. That often happens when changing dizzys. All you do is, with the distributor still in (but not in all the way because of the mismatched slot) is rotate the crank. That will rotate the dizzy button with the camshaft and crank keeping everything "in time" until the dizzy is able to slide down on the oil pump slot at the correct angle.
After that you can do one full rotation of the crank until you are back at TDC and double check your rotor button is for certain at the number 1 firing position.
This will get you at 0 BTDC or pretty close to it. It should run.
Go ahead and set your timing with a timing light and advance to 6 BTDC.
Just tryin to help.
Couple of questions, how did you set valve lash? You had all that stuff apart, so we need to visit that too.
Regarding the 180° out question, does the mark on your distributor show the rotor pointing at #1 plug wire? If you were on exhaust stroke when you marked it, it would be pointing opposite #1. And, if so, as stated above, were you on compression when you reinstalled it?
Okay, a couple is two, but there's one more. Being only a 1/4" out is it possible that you turned the engine opposite of rotation at any point to align the timing marks? Turning an engine backwards reverses all the slop in the timing train and can mean several degrees of mismatch between the crank and the driven components compared to how they normally operate.
Okay, two more. How many miles on the engine? Those nylon covered timing gears can cause all kinds of unpleasant timing issues when they fail.
I do recall that I turned the engine the opposite direction maybe a quarter of an inch, which makes a lot of sense
. Does this mean my engine is screwed? I didn't think that such a small amount would cause so many issues, guess that shows how much I know. My engine has 90,000 miles on it, so not terribly high but also not young.
Just tryin to help.[/QUOTE]
I appreciate the response and advice, always looking to learn some new! I am very sure I was on the compression stroke, as I felt air being pushed out of the cylinder as I turned the engine over by hand. I have also heard that when the engine is 360 degrees out of phase it will backfire when you try to start it. Mine doesn't backfire at all, it just spins and spins.
Based on other posts here, and general experience 90K is near the timeframe when the nylon gear teeth tend to fail. Try barring the engine in both directions with the cap off the distributor. The rotor should move with a few degrees of rotation. If it takes a lot of movement when you change directions the timing gear may be shot.
They'll still run that way tho, so that also does not explain a no-start. My next guess would be to do a compression test. That would tell you if something is up with the valve train or the timing chain.
I'll have to pick up a compression tester asap. If I find I have low compression, does this mean my valve train is screwed up?
I couldn't tell you exactly in degrees, but it should respond pretty quickly. There's not a lot of slop in a healthy timing chain and the cam / distributor gears.
Low compression would likely point to a valvetrain issue, especially if it's evenly low across all cylinders. @$$uming you had good compression before you started on your project.
In racing we had a "only change one thing at a time" rule. But it's true for all situations like this. It worked before, and now it doesn't. What was the last thing you did? You've did several things here, so we have to look at all of them. The other possibility is that it was just lousy coincidence. But that's way less common.
I realize now I really should have check compression before starting this project, it just ran so well I didn't even think to do so. Fired up right away all the time and good power.
Here's kinda a brief explanation of the steps I took:
1. Set lash based on the 1986 Vette manual
2. Found TDC on cylinder 1 by placing my finger over the spark plug hole and felt compression.
3. Lined up my distributor with my marks as best I could (roughly 1/4" off) pointing at cylinder 1
4. Checked and double-checked my spark plug wires to make sure they were correct.
5. Turned engine over several times = no start. Turned engine over while pulling throttle cable = no start.
6. I adjusted the distributor about 1 tooth clockwise, this resulted in a very loud backfire.
7. I moved the distributor back to the position I had it in before because I got scared lol
That's all the major stuff I've done so far.
I didn't have time after work to pick up a compression tester, but I decided to try the whole timing process over again. Everything went the same way, the engine would not fire. However, this time I noticed raw fuel actually spraying out of the intake manifold!! I just installed Bosch III injectors rated at 22lbs of pressure (I think I said they were new in a previous post, I meant to say remanufactured by SouthBay Fuel Injectors). Anyone know what would cause so much fuel to spray out? Could it be an issue with my fuel pressure regulator? I turned the engine over for about 5-7 seconds without it firing. Is that enough time to build up so much fuel in the cylinders that it would spray out of the intake? Sorry for so many questions, just trying to get somewhere, seems like it's only getting worse.
