85 seats
Old Jan 2, 2025 | 02:49 PM
johnfin's Avatar
johnfin
Default 85 seats
Any of you guys use the trapeze straps to replace the broken wires in the seat bottom. Also, are 1990 seats the sane as 1985 seats. Will they fit?
Old Jan 2, 2025 | 07:41 PM
sb66's Avatar
sb66
I used those when i replaced the seat covers and foam - not sure there was much of a difference in feel because the foam was changed at the same time - easy enough job - hope that helps
Old Jan 2, 2025 | 07:48 PM
ductape's Avatar
ductape
Cruise-In V Veteran
I have not made the swap, but after looking at the spring/wire set up in mine, I think it's a mighty fine idea. Has to offer better support and feel. Does anyone know when the change from the springs to the straps occurred?
Old Jan 2, 2025 | 07:52 PM
sb66's Avatar
sb66
not sure - i was just looking around someone else used an extra set of straps - hooked up 4 instead of the 2 in the kit - looked like a solid idea
Old Jan 2, 2025 | 07:53 PM
sb66's Avatar
sb66
https://www.corvetteforum.com/forums...provement.html
i think this is right
To 85 seats
