Coolant Leak Detected
Old Nov 17, 2025 | 05:05 PM
TaurusFergie's Avatar
TaurusFergie
Cruising
Default Coolant Leak Detected
I found the source of my coolant leak, but I don't know the specific name of this house (the hose with what looks like heat wrapping). Anyone know?
Old Nov 17, 2025 | 05:10 PM
ramahon's Avatar
ramahon
That is the EGR pipe, definitely not your source of coolant leak. Where are you seeing fluid?
Old Nov 18, 2025 | 04:20 AM
TaurusFergie
Cruising
Originally Posted by ramahon
That the EGR pipe, definitely not your source of coolant leak. Where are you seeing fluid?
It looks like coolant is leaking from here.
This is where it was pooling when the engine was running.
Old Nov 18, 2025 | 08:42 AM
ramahon's Avatar
ramahon
@TaurusFergie
EGR pipe doesn’t carry any coolant, strictly gases. So I understand correctly, the coolant was pooling under the pipe, just above the valve cover there?
Old Nov 18, 2025 | 09:43 AM
TaurusFergie
Cruising
@TaurusFergie
Correct
Old Nov 18, 2025 | 09:53 AM
2011KLR's Avatar
2011KLR
Don't crush me if my memory is wrong, but isn't there coolant running through the pipe to the left of his circle?
Old Nov 18, 2025 | 06:08 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Yes. Technically it's an air bleed, but coolant does run through that one.
Old Nov 19, 2025 | 01:12 PM
ramahon's Avatar
ramahon
@TaurusFergie have you checked the threads for where that adjacent line that was mentioned by @2011KLR meets the lower intake?
Can't imagine it is the hose clamp given where it meets the fixed line. Here is a thread of other members discussing its necessity towards cooling. My takeaway is that it could be capped without issue but please read and make your own conclusions!
Old Nov 24, 2025 | 06:33 PM
ramahon's Avatar
ramahon
@TaurusFergie did you get this sorted out?
To Coolant Leak Detected
