Passive Annoying Keyless Entry...
Old Apr 10, 2003 | 05:26 PM
JasonL's Avatar
JasonL
Default Re: Passive Annoying Keyless Entry... (ODA CDR)
ODA CDR, you can still use the power door lock switch to arm the alarm :) It does not rely on PKE.
Old Apr 10, 2003 | 06:08 PM
Reno67's Avatar
Reno67
Default Re: Passive Annoying Keyless Entry... (MinnesotaWhite)
Good idea Minnesota White, I have not thought of that. I wished the fob would lock and unlock the doors when the auto mode is turned off, too. But I guess GM did not want that function available, for some reason.
Old Apr 10, 2003 | 06:54 PM
timmb001's Avatar
timmb001
Default Re: Passive Annoying Keyless Entry... (96GhostLT4)
PKE on my 1996 quit working. Anyone kno whow to do diagnosis on it? FOB's work fine on another vette.. So it must be in the Dash somewhere...I just dont know how to check it...????
Old Apr 10, 2003 | 08:49 PM
JWG's Avatar
JWG
St. Jude Donor '07
Default Re: Passive Annoying Keyless Entry... (stinger95)
I love mine. Very :cool: feature.
:iagree: ............................. :D
Old Apr 10, 2003 | 10:11 PM
lspalding's Avatar
lspalding
Default Re: Passive Annoying Keyless Entry... (JasonL)
When you hit the unlock button, what you're hearing is the passenger door unlock. The unlock button on the fob will not unlock the driver's door (go figure).
Thanks, I thought mine was broken.
Old Apr 10, 2003 | 11:23 PM
96CEC4's Avatar
96CEC4
CI 4-8-9 Veteran
St. Jude Donor '07-'08
If you leave the key in the ignition...it will not lock the doors...so when I wash it or fill the car with gas...key stays in the ignition!
I really like it...get out...key in pocket and walk away! Don't push anything!
I got locked out doing this.... I even tried "rocking" the car to wake it up. Didn't work. Thank goodness my wife was home to bring me a spare key...
Matt
Old Apr 11, 2003 | 11:19 AM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: Passive Annoying Keyless Entry... (corvette-pilot)
Just have to turn it off when hanging around the car.
:withstupid: I love the PKE, it's the coolest keyless entry system i've seen :cool:
Old Apr 11, 2003 | 04:51 PM
n1kki6's Avatar
n1kki6
Default Re: Passive Annoying Keyless Entry... (GoodbyeGirl)
When people first talk to me about the car i will always tell them its got a cool feature, that the car knows when i'm buy it and automattically unlocks and no one can ever figure out how. I never tell them either.
Old Apr 11, 2003 | 05:03 PM
rubyred93's Avatar
rubyred93
Default Re: Passive Annoying Keyless Entry... (n1kki6)
I guess I'll be the first to say that I never use my PKE keyfob, and I don't like the system. The fob has been collecting dust since I bought the car 2 1/2 years ago.
I prefer to lock and unlock my doors myself. I just don't find it to be a convenience feature. Same thing goes for the automatic stereo volume...I'll adjust that myself as well, thank you. :nono:
Old Apr 11, 2003 | 05:13 PM
bluestreak63's Avatar
bluestreak63
Default Re: Passive Annoying Keyless Entry... (rubyred93)
If you don't use the keyfob, does it still arm the factory alarm system? When the keyfob is active and I walk away from my car, I can hear the doors lock and the horn beeps letting me know the alarm system activated. Yes, the keyfob is nice, but mine is starting to go and I don't think it's the battery because I just replaced it.
Old Apr 11, 2003 | 08:44 PM
JasonL's Avatar
JasonL
Default Re: Passive Annoying Keyless Entry... (bluestreak63)
bluestreak, yes it's possible to arm the alarm without PKE.
Open the door (SECURITY light flashes)
Lock doors using power door lock switch (SECURITY light becomes solid)(Note: you have to use the power door lock switch...using the door lock slider or outside door lock key won't arm the alarm)
Close door
The alarm is now armed. You can verify this by doing it with the windows down, then reaching over and hitting the door lock switch. The horn should start blaring.
Likewise, the alarm is disarmed by using the PKE remote, OR inserting the door key into either door and turning the lock.
[Modified by JasonL, 5:46 PM 4/11/2003]
[Modified by JasonL, 5:48 PM 4/11/2003]
Old Apr 11, 2003 | 10:29 PM
MinnesotaWhite's Avatar
MinnesotaWhite
Default Re: Passive Annoying Keyless Entry... (96CEC4)
Matt
Then yours is broken...get it fixed...my owners manual suggested doing this.
