Help with LT4 refusing to start
Old Apr 30, 2003 | 02:33 AM
96-white-LT4's Avatar
96-white-LT4
4th Gear
Default Help with LT4 refusing to start
I left my LT-4 in my garage for 2 months and it had stubbornly refused to start ever since. The starter is cranking strong and there are spark on the wire. The center console does not display any warning light.
I do not have any OBDII reader, but tried to short two of the pins to bring up the diagnostics code as I had read in forum. The dashboard displayed sub-system 1 and code H-71, H-72 [ Fuel too lean / Fuel too much ].
Any idea what's wrong this is car? Am I looking at a new computer management system??
I live in LA / Santa Monica area. Please let me know if you have a know of a reliable shop that knows how to fix C4-LT4.
Thanks !
Benjamin
Old Apr 30, 2003 | 10:38 AM
GS919's Avatar
GS919
Default Re: Help with LT4 refusing to start (96-white-LT4)
Welcome to the forum! :seeya I would suggest that you repost this in the C4 Tech/Performance area, probably will get a quicker response from one of the experts. Also, are you getting fuel? Might want to check to see if you have pressure. Good luck!
Old Apr 30, 2003 | 11:45 AM
redwing76's Avatar
redwing76
Pull a plug to see if its wet (fuel).
Fuel in tank? Spray a carb cleaner into the air intake. If it starts to run you have a fuel problem. Don't drowned the air intake with crab cleaner, just a small spray will do.
If it trys to run it might be the fuel pump relay. If the fuel pump relay is out the car wont run.
Old Apr 30, 2003 | 10:26 PM
96GS#007's Avatar
96GS#007
The codes you pulled are CCM codes, not PCM (Powertrain) codes. You can not pull OBD 2 PCM codes by shorting pins like you can on older C4s. The OBD 2 codes are 5 digits long (Pxxxx) while the speedo display is only 3 digits.
Since you have spark, then that indicates a fuel problem. Verify the fuel pump and injector fuses are good. Verify fuel pressure. When you turn the key to "run", do you hear the fuel pump run? If not, you have a pump or wiring problem. Have you checked the fuel pressure regulator? Any fuel in the vacuum line? If so, the regulator is bad. Any fuel on the plugs? How did you verify spark?
As you can tell, not an easy problem to resolve.
Old May 1, 2003 | 12:59 AM
96-white-LT4
4th Gear
Default Re: Help with LT4 refusing to start (96GS#007)
Thanks for the suggestions... Here is what I had done so far.
1. With Key in, but not cranking, I can hear the fuel pump in the back of the trunk. [ at least that's what I thought it was ]
2. I will check the fuel injector fuses. [ I also did a quick check on all fuses in the main fuse box. Are the fuel injector fuses located in the main fuses box?
3. Verify fuel pressue.... Lots like I have to buy or rent a measurement tools. So I will go to my local pep boys and see what they recommend..
4. I verified spark with a inductive spark indicator on the spark plug wire. So that should be reliable.
5. No I have not pulled the spark plugs cause I dont have my usual tool chest with me.
As you had pointed out.. This does sounds like a pretty complicated problem. I was hoping that it might be more common. Looks like I have to book an appointment with my local Santa Monica chev dealer....$$$
Thanks for your suggestions !
Benjamin
To Help with LT4 refusing to start
