LT1 Life Expectancy
Old Oct 13, 2003 | 07:53 PM
Texas CE's Avatar
Texas CE
Default LT1 Life Expectancy
So who has turned in excess of 100K on their LT1 and what problems have you experienced?
I just turned 59K on my CE and it runs/drives like a new car.
Is there any reason to not think this car could roll on past 200k with normal maintenance? :auto:
Old Oct 13, 2003 | 07:55 PM
xlr8nflorida's Avatar
xlr8nflorida
Default Re: LT1 Life Expectancy (Texas CE)
should go 200,000 if you don't beat the snot out of it.
I had 134,000 on my 92 when I sold her and she still ran strong :smash:
Old Oct 13, 2003 | 08:12 PM
Dan Parker '96's Avatar
Dan Parker '96
I tore mine down at 106K for a quick refreshening during my LT4/Hotcam conversion. I felt like I wasted money on replacing the rings and bearings. Looked brand new.
Opti looked pretty good. A little worn but a new cap & rotor went on.
Waterpump was fine. Replaced it anyway.
Oil pump clearances were like new. Already had the new one so it went in.
Even the original spark plugs looked damn good (all pucks in place, gap OK). Naturally plugs & wires got replaced (although it ran perfectly fine on the old stuff)
I really could've gotten by on just replacing all gaskets and seals and probably run another 100K. Everything else looked great.
[Modified by Dan Parker '96, 7:19 PM 10/13/2003]
Old Oct 13, 2003 | 08:37 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
119,000 hard hard miles and still going strong.
Old Oct 13, 2003 | 08:38 PM
CanadaVette's Avatar
CanadaVette
These are strong cars made to go strong. I think you could pass the 200 mark with very little work except for the usual stuff. Opti/waterpump.
Old Oct 13, 2003 | 08:41 PM
bogus's Avatar
bogus
Default Re: LT1 Life Expectancy (CanadaVette)
Mine has 118k miles, and runs like a top!
Leaks like a sieve, but runs great!!!
And, surprisingly, looks pretty good doing it! Ask Mojo, he has seen it!!!
Old Oct 13, 2003 | 09:04 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Default Re: LT1 Life Expectancy (bogus)
Though I only recently joined the Corvette family, I bought my '95 with 138K. Since I tore it down to do a rebuild, I can tell you that the rings were actually pretty decent, the cylinders weren't really egg shaped however the rod bearings were in need of replacement. I could tell that part of the problem was the previous owner must have let the car run low on oil. I don't think if that had happened, the bearings would have probably lasted even longer.
I don't think most GM's (especially if they're driven a little more aggressive like vettes) will last a full 200K. I realize that there are exceptions to the rule but I think most GM V-8's will typically last 140-150K before a rebuild is a good idea. Again, a general rule, not steadfast...
Just my .02
Mark
Old Oct 13, 2003 | 09:42 PM
96redvette's Avatar
96redvette
173,000 miles and counting. I just replaced the entire ignition including opti and water pump. I've only had it about 5 months, but the previous owner drove across country for business quite often. It runs VERY strong. :auto:
Old Oct 14, 2003 | 12:23 AM
Quiktrp94's Avatar
Quiktrp94
Default Re: LT1 Life Expectancy (96redvette)
205,000 and counting. Got it almost 2 years ago with 184,000 on it. I don't know the history of it but I don't believe it has been rebuilt. I did waterpump and plugs and wires, but otherwise running great. Knock on wood!!! :cheers: :steering:
Old Oct 14, 2003 | 12:29 AM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: LT1 Life Expectancy (rspvette)
almost 121k and I just replaced the opti and waterpump, otherwise it runs perfectly :D
Old Oct 14, 2003 | 12:43 AM
jodyeastman's Avatar
jodyeastman
Default Re: LT1 Life Expectancy (_freakmonkeydogboy_)
115000 KM and running great! :chevy
Old Oct 14, 2003 | 01:23 AM
Goody's Avatar
Goody
Default Re: LT1 Life Expectancy (jodyeastman)
148,000 and valve covers have never been off. Will still do the 1/4 in under 14 secs....just not with me driving. :steering:
Old Oct 14, 2003 | 04:08 PM
Stv50's Avatar
Stv50
:lol: Wow, I have a long long way to go. :thumbs:
Old Oct 14, 2003 | 06:42 PM
Texas CE's Avatar
Texas CE
Default Re: LT1 Life Expectancy (Stv50)
Great responses everybody! have put about 12K on it in the 3 years of ownership so I should have 100K/ 25 years of life left barring an unforeseen circumstances (Impacts, Theft, Divorce, IRS seizures, the usual). Yeah! :steering:
Old Oct 15, 2003 | 11:36 AM
Dudule's Avatar
Dudule
105 K and run as smooth as a......Vette
:thumbs:
Old Oct 15, 2003 | 12:14 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: LT1 Life Expectancy (Mr Mojo)
Approaching 96 thou and mine still runs like new money! :thumbs:
Old Oct 15, 2003 | 12:20 PM
GRNVNM93's Avatar
GRNVNM93
Default Re: LT1 Life Expectancy (onedef92)
136,000 miles with only the waterpump replaced a couple thousand miles ago. Running strong!!! My dad(a Ford man) gives great credit to Chevy's small block V8s!! :seeya
To LT1 Life Expectancy
Old Oct 15, 2003 | 01:29 PM
QuikZilver's Avatar
QuikZilver
Default Re: LT1 Life Expectancy (GRNVNM93)
I have over 154,000 on my 93. Only engine parts that have been replaced have been opti, water pump, intake gasket. That is it. :smash: Hope it lasts to at least 300,000!!
:steering:
Old Oct 17, 2003 | 05:56 PM
RangerZR-1's Avatar
RangerZR-1
Cruise-In III Veteran
95 LT-1 has 130,000 and is all original (opti, water pump, everything but plugs)
Old Oct 17, 2003 | 08:23 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
108K miles - Daily Driver and weekend show-n-shine , I had the factory plugs and wires on it until two weeks ago and it still pulled 250 RWHP at the Dyno last spring. I put new plugs and wires on it two weeks ago at a club Mod-Day and I could immediately tell a difference in the way the car ran. It had a better, smoother rev-up and slightly stronger and smooth exceleration. Love'n it. I hope it goes another 100K
:thumbs:
