Front Spring Compresseor Tool
Old Jan 24, 2004 | 02:08 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default Front Spring Compressor Tool
Anyone ever see the front spring compressor tool diagrammed in the factory shop manual? Part number is J33432. Or for that matter anyone know if one is available to rent? Its a long shot question, just had to ask.....
Should I get really lucky and somebody has, or knows of one that is available to rent, please post here, IM or email me..
:cheers:
JrRifleCoach
:banghead: I really hate it when I mispell a word in the topic box :banghead:
[Modified by JrRifleCoach, 11:10 AM 1/24/2004]
Old Jan 24, 2004 | 08:09 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Front Spring Compressor Tool (JrRifleCoach)
You don't need it.
Just put front of the car on jackstands remove a wheel, support the spring load (lower control arm) with a floor jack (watch out for the zerk fitting), pull the lower ball joints, disconnect the shock, and slowly lower the floor jack to relieve spring tension.
The shock extended limit is what keeps the spring from moving everything too far and tearing the ball joints out.
Old Jan 24, 2004 | 08:10 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You really don't need it. :smash:
What are you up to Steve ??
Thanks a million for the disc. :thumbs:
:seeya
Old Jan 24, 2004 | 08:35 PM
JrRifleCoach
Default Re: Front Spring Compressor Tool (AGENT 86)
You really don't need it. What are you up to Steve ??
Your welcome :thumbs:
The wife saw the post of your Vette up on jack stands and freaked on me. So to put her mind at ease, I promised I'd try to find a spring tool to keep her from locking me out of the garage! :lol:
After reading everyones posts, it appears that lots of height and being careful is the key. The process is just like the removing the rear spring. One side at a time. Slow and easy...
Looking at your post, would it be easier to have the car level?
:cheers: -JRC-
Old Jan 24, 2004 | 09:26 PM
AGENT 86's Avatar
AGENT 86
:nonod: That would bring the front end down and you want it as high and safe as humanly possible :thumbs:
Old Jan 24, 2004 | 11:17 PM
JrRifleCoach
I like your touch with the wood under the jack stands. Looks the "the ticket"!
Old Jan 25, 2004 | 03:54 AM
CentralCoaster
Here ya go. Would you like cheese with that?
http://forums.corvetteforum.com/zerothread?id=738328 :cheers:
Old Jan 25, 2004 | 12:37 PM
JrRifleCoach
Default Re: Front Spring Compressor Tool (CentralCoaster)
That is one impressive piece of work. Thanks! The War Dept should release my stay of execution and return my rights to the garage after reading this.
I haven't hurt myself before, but there are times I could relate to "Tim the Tool Man"..........even had a Corvair like his :yesnod:
:cheers: -JRC-
To Front Spring Compresseor Tool
