headlamp switch question
Old Jul 2, 2004 | 05:13 PM
Chewch87's Avatar
Chewch87
Default headlamp switch question
Before I force anything Or break it how does the round headlamp switch come off or out of the dash?? Does it pull out or screw out to the left??? The original is a little stained on my 87 and I'd like to change it out.
Old Jul 2, 2004 | 05:21 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Default Re: headlamp switch question (Chewch87)
Most GM HL switch ***** are held into the switch body by a detent. There is usually a button on the switch body that will release the ****....the problem is accessing the switch body and finding that release!
Goooooooood luck!
Larry
Old Jul 2, 2004 | 05:23 PM
Bilyk's Avatar
Bilyk
it pulls out to the best of my knowledge
can i have the old one?
Old Jul 2, 2004 | 05:25 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you rotate the **** you will see (using a small mirror) a spring clip that grips one edge of the triangular shaft.
Use a small flat blade screw driver to depress the clip (push it toward the black ****) and pull the **** off the shaft.
Old Jul 3, 2004 | 10:27 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: headlamp switch question (65Z01)
Now where did you find your replacemant, and how much ??
Old Jul 3, 2004 | 02:03 PM
65Z01's Avatar
65Z01
Default Re: headlamp switch question (AGENT 86)
I bought the **** & shaft from Contemporary Corvette (link on my site) for $8....P/N 34225, '94-'89 Headlight **** w/rod.
To headlamp switch question
