Changing fuel filter
Old Jul 9, 2004 | 01:46 AM
black_89_vette's Avatar
black_89_vette
Default Changing fuel filter
I ended up running out of gas due to a faulty gas guage. Anyways, it's time for a replacement, so what's everyone's choice for a new fuel filter?
K & N, OEM or any aftermarket?
Old Jul 9, 2004 | 02:28 AM
Wayne88's Avatar
Wayne88
I just use the standard AC Delco.
I change it about every 5K miles.
At $14, Its good low cost protection for the injectors
& you never know if you get a bads tank of gas..
Old Jul 9, 2004 | 07:30 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
I use the AC Delco too......it can be a pain in the *** to remove the filter if you havent done it before. WHen I did mine, I released the pressure but the fuel still flowed when trying to remove the filter.....I ended up running the tank almost empty to get it to stop.
Old Jul 9, 2004 | 07:33 AM
jabez's Avatar
jabez
I don't thinkt really matters for a fuel filter. All the same to me.
Old Jul 9, 2004 | 08:05 AM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Nothing special needed if you ask me! Which you did!
-Rick
Old Jul 9, 2004 | 03:18 PM
myblue91's Avatar
myblue91
For what it's worth,AC Delco
Old Jul 9, 2004 | 04:13 PM
TheStef's Avatar
TheStef
I'll be changing mine tomorow, I ordered it from GM.. not sure who makes them for GM.
I'm not certain how to proceed with the fuel filter change, I'm guessing theres just a suporting braket to unbolt and then just unbolt both ends of the fuel filter and put the new one on.
I will remove the gas tank cap, but my tank is almost full..... hmmm what would be the best way to make certain I don't lose all my gas on the garage floor?
Old Jul 9, 2004 | 04:18 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
While some will release pressure, I say put a drip tray (pie tin) under it and open it up - you will not have that much gas come out - or let it sit for a couple hours once up on ramps.
Gas from the tank would need the fuel pump on to flow out like you are thinking
Old Jul 9, 2004 | 05:03 PM
TheStef's Avatar
TheStef
Thats what I originaly though, but after Bruthish post I though that somehow gas would keep leaking out.
Thanks for reasuring me
Old Jul 9, 2004 | 05:37 PM
*89x2*'s Avatar
*89x2*
that post was indeed interesting - I am not sure why on that one, but mine did not run till dry...
Old Jul 11, 2004 | 10:53 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I think if you ran almost twenty gals. of gas all over the ground, you would probable be getting a visit from your local fire dept.
Old Jul 12, 2004 | 01:12 AM
GKK's Avatar
GKK
Check out the Tech article I wrote titled, "89" fuel filter replacement in the C4 Tech section.
Old Jul 12, 2004 | 08:08 AM
TheStef's Avatar
TheStef
Changed the fuel filter this Saturday, It was way easier then expected.
It did leak a bit, but I was still able to change the filter wile the gas was leaking, I got my hands full of gas but that honestly doesn't bother me.... who else here likes the smell of gas?
Since I have a convertible, the only hard part of the job was removing one of the X fame beams to access the fuel filter.
Old Jul 13, 2004 | 09:09 AM
shotchkiss's Avatar
shotchkiss
Also be sure to remove the gas cap to let the pressure out of the tank, that way not as much gas will leak out for you.
To Changing fuel filter
