PKE Going Crazy
One day I was, cleaning up my car, radio on keys in the ignition and PKE goes crazy, the light on the info counsel is on and the hatch keeps popping open, maybe every 20 seconds. It simply won't stop, turning car on and off doesn't help. So, I pulled the fuse that delas with PKE.
Here's where the story gets good: I'm driving in the Ted WIlliams Tunnel, in Boston last nigh during rush hour and . . . PKE light goes on the info center, door locks pop open and the hatch pops open too.
Has anyone had this happen, I didn't even have the fuse back in, how could it be activated.
Is there a gremlin in my Corvette?THanks
for reading.
Seriously, without a transmitter I'm not sure how to disengage passive mode. I looked through the diagnostics and did not see anything related to activation on its own. You definitely should have the manuals to do a proper diagnosis.
One thing comes to mind and that is a short in a circuit somewhere. Something (the PKE) is sending the signal to the UTD (Universal Theft Deterent) to open these items. The fault on the Info Console may have set a code and you may want to check to see if there is one retained.
You may also want to give Chris a call at Superior and order a transmitter, it should be $94. plus shipping. Program it and see if the problem goes away since you'll now be actively using the system. You can disengage passive mode with the transmitter by pressing and holding longer than 2 sec on the door button of the transmitter with the door open and key out of ignition. It cycles the locks and either turns it off or on, depending on which mode it was in. However, with the transmitter you may wonder how you did without it!
