engine install with long tubes ??
Feb 2, 2005 | 10:37 PM
NoVa Events Coordinator
St. Jude Donor '14
Can you install a LTx with long tubes on?
Feb 2, 2005 | 11:02 PM
well u cant with the trans on and they stick out past where the trans comes into the engine... IDK
mayeb this will help or give ur thread a boost and someone more qualified will awnser.
your friend
Sean
Feb 2, 2005 | 11:03 PM
how long are your tubes? the 'full length' headers are 30", and then there are 26" headers, both made by hooker. i've run to 30"ers and the cut the collector off and welded on the flowmaster 4-2-1 collector, adding about another 12" to the length. a little tricky getting a collector flange on and making the bend in the floor pan
Feb 3, 2005 | 01:08 AM
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'd install them after. Access is pretty good on the bolts and they should slip right up into place. I just think that'd be easiest.
Feb 3, 2005 | 01:20 AM
easier and safer...remember haste makes waste haha..
well ne wayz
good luck your friend
Sean
Feb 3, 2005 | 07:28 AM
St. Jude Donor '14
Feb 3, 2005 | 06:30 PM
Feb 3, 2005 | 06:42 PM
St. Jude Donor '14
Feb 3, 2005 | 06:47 PM
St. Jude Donor '11
Quote:
Originally Posted by Bluewasp
383 with EM long tubes
I just got my 396 going, but am having problems with coolant seeping at the heads.....hope your install goes smoother than mine has.
jeff
Feb 3, 2005 | 06:55 PM
St. Jude Donor '14
Quote:
jeff
I'm "knocking on wood"... I hope so.....
good luck.
Feb 3, 2005 | 07:03 PM
Then you DEFINITELY don't want to take a chance banging up those beauties trying to install them w/ the engine!
Feb 3, 2005 | 07:10 PM
St. Jude Donor '14
Ok..
Do you install the EM long tubes from the top or bottom?
Feb 3, 2005 | 07:14 PM
St. Jude Donor '11
Ok..
Mine are TPIS...they went in from the bottom. the pass side was a little tighter than the drivers side was.
jeff
Feb 3, 2005 | 09:33 PM
What are the specs, what kind of heads? How much power are you expecting?
