top speed 160mph observed
160mph observed
275/40/zr17 tires
6000 RPM observed
overdrive in 4L60 trans is .70
RACE ON!!!
www.f-body.org is a good one to use.
My mistake...not a 3.07...just surprising someone did the swap and didn't tell you prior to you purchasing it as 3.07 and 2.59 were the only gears you could get with an automatic.
160mph observed
275/40/zr17 tires
6000 RPM observed
QUOTE]
These numbers don't really make sense..
With this size tire it takes about 801 revs to go one mile, at 160mph you are going 2.67miles per minute, so the tire is turning 2136 rpms..
If the motor is turning 6000 rpm, then the drive shaft is turning 8571rpm.........
So rearend ratio is 8571/2136=4.01
If you were actually in 3rd gear..1:1 driveshaft would be turning 6000rpm
So rearend ratio is 6000/2136=2.81.....
My guess is you have 2.59.....the tires grew at speed and/or you were actually going a little less than 160 and/or you were actually a little less than 6000 rpms...
OOPS!!! 801 rev per mile is for 285's......810 rev per mile is for 275's
So tire at 160mph is turning 2160 rpm....
So axle ratio is 8571/2160=3.96 if in 4th gear
So axle ratio is 6000/2160=2.777
You had to have been in 3rd gear not 4th....
RACE ON!!!
RACE ON!!!
The axle ratio then is 8571/2160=3.96
Why not mark the driveline and the tire? Put the car on stands and see how many revolutions the tire makes for each revolution of the driveline.
really?
I didn't know that a D-36 carrier could accept that ratio!
other info-
1st gear top speed is 60mph (apprx)
2nd is 100
3rd is 145
4th is 160
and to my knowledge, the gearset has NOT been changed.
RACE ON!!!
You might take the advice from neat, and count turns.
RACE ON!!!
Naw but there radios and spike strip catch up fast
I was "clocked" at 145MPH slowing down from a run on 18. 14Psi boost 3.42 and 6,200 RPMs in 4th (A4) Speedo was pegged LONG after I let up before going into a three car trap
but for the sake of argument, lets plug in the numbers- IF i was to be going 160mph in 3rd gear at 6000 rpms, what would the gearset be?
another interisting problem.... I tried to top end last weekend and it would not stay in OD. it shifted back and forth between 3rd and od and acted retarded untill i stuck the selector in "D" and put it to the wood. I pegged the tach out at 145mph and got out of it. the tranny would not let the car go any faster. so WHY, when on tuesday night, it pulled OD clean to redline at 160mph?
RACE ON!!!
160mph observed
275/40/zr17 tires
6000 RPM observed
QUOTE]
Since there seems to be some question as to whether you were in 3rd or 4th gear and your question is what is your rearend ratio, why not repeat it to be sure what gear you are in....
Actually why not just take it up to say 60, be sure which gear you are in, and get a tachometer reading.........
or 80mph would be half of 160, so check tach at 80 in 4th and if necessary again in 3rd......one of should be taching 3000 rpm..
and that includes dynos!!!
