I was just re-reading an article from the 12/98 issue of Corvette Fever by Chris Petris where he says "lube the suspension and drivetrain." What parts of the drivetrain should be lubed and how? (as info, I regularly service my 700R4's fluid/filter and the diff's gear oil).
Thanks!
Vance
Reason: add info
The Redline has the lim. slip additive already in the oil. I've had no problem at all with the rear gears just using the Redline w/o the GM additive, even tho I have two bottles of it on my shelf just in case.
