Can someone ID this cam?
Old Feb 15, 2005 | 07:45 PM
ALLT4's Avatar
ALLT4
Default Can someone ID this cam?
I believe it may be an older CompCams grind for an LT1. I tried calling that silly tech help line but nearly died waiting for a rep.
Old Feb 15, 2005 | 09:04 PM
mean8t's Avatar
mean8t
Tried emailing them yet?
Old Feb 15, 2005 | 11:36 PM
hookedup's Avatar
hookedup
If you can download their "Master Cam" catolog you can look up grind #s for lobes 3314 & 3315. That will give you the lift at various rocker ratios and duration in degrees as advertised, @.050 & @.200.
The 12+4 is that the cam was ground with 112 Lobe Seperation Angle(LSA) and it's 4 degrees advanced(pretty much standard practice).
I don't have the catalog handy tonite or I'd look up the grind specs for you, if you don't have any luck tomorrow I'll try to locate my master sheets.
Good luck,
Dave
Old Feb 16, 2005 | 01:30 AM
tjwong's Avatar
tjwong
If that is a Comp Cams custom grind it is a 224/230 ground on a 112 LSA with 4 degrees of advance. The lift specs are .536/.544 with 1.6 rockers. These are their extreme cam lobes.
Old Feb 16, 2005 | 07:17 AM
ALLT4's Avatar
ALLT4
How did you come up with that information from those numbers?
Old Feb 16, 2005 | 10:08 AM
tjwong's Avatar
tjwong
I looked up the lobe numbers in my trust Comp Cams master catalog. The rest was easy:
HR12 = Hydraulic roller with a 112 LSA
+4 = 4 degrees of advance
Old Feb 16, 2005 | 11:43 AM
Red Tornado's Avatar
Red Tornado
yup, says so right here:
http://compcams.com/Technical/Curren...ML/238-273.asp
Old Feb 16, 2005 | 12:37 PM
ALLT4's Avatar
ALLT4
Originally Posted by bradvette
AHHH, thank you for that link! I just couldn't find it somehow. Now the last question is would this cam be alright for a 383 LT1 with ported LT1 heads we are building? I think it may be a bit small after looking at all the specs. Maybe someone with a dyno program could run it, pretty please?
Old Feb 16, 2005 | 02:45 PM
mean8t's Avatar
mean8t
How much power are you looking for? That cam should be able to push 400-450 chp with 1.6's. However if you want a bigger cam then maybe 3192/3194 lobes with a 112 LSA. They are the same 224/230 dur but have .567"/.584" with 1.5's as opposed to .503"/.510" with the cam you got. Those lobes would have .605"/.622" with 1.6's. That would be a mean cam even in a 383.
Old Feb 16, 2005 | 03:00 PM
ALLT4's Avatar
ALLT4
You know you're absolutely right. I wasn't thinking about the different ratios. My bad.
Old Feb 16, 2005 | 03:21 PM
mean8t's Avatar
mean8t
What about the different ratios?
Old Feb 16, 2005 | 08:11 PM
ALLT4's Avatar
ALLT4
Rocker ratios, I was only looking at 1.5:1
Old Feb 17, 2005 | 09:44 AM
mean8t's Avatar
mean8t
I think the cam you have would be a great cam, with 1.6's or even 1.7's. What are you doing to the heads?
Old Feb 17, 2005 | 12:25 PM
ALLT4's Avatar
ALLT4
Larger valves are being cut in. Manley necked down valves. Heads were already ported and further cleaning up and blending is being done. Port matched to an LT4 intake. The spring pockets are being cut for Comp Cams 986 dual springs 1.43 dia. these are the springs to match the cam. I think the cam with 1.6 rollers will be sufficient. I could go on with other stuff but you get the idea, pretty much nothing but all high perf. stuff.
The bottom end will be all forged 383 H-Beam, with ARP mains, rods, and head studs.
Sound good?
I just wish it was my car we were working on.
Old Feb 17, 2005 | 02:09 PM
mean8t's Avatar
mean8t
Sounds great. Should be a killer motor.
To Can someone ID this cam?
