Rollbar strength
Old Feb 17, 2005 | 09:18 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Rollbar strength
For those of you who have been considering a rollbar from DRM, EM or RD, this is to show you how much more rigid everything is.
Normally when you jack from the rear, the front tire of the same side is the one lifted off of the ground. At this height, the front tire is still on the ground.
Old Feb 17, 2005 | 09:28 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Damn Jeff... there is little to no suspension flex left!!!
That is nice
Old Feb 17, 2005 | 09:31 PM
6spd's Avatar
6spd
what is installed in this car?? i want the s/t frame support will that work good?
Old Feb 17, 2005 | 09:36 PM
Jeffvette's Avatar
Jeffvette
DRM bar.
Old Feb 17, 2005 | 09:43 PM
6spd's Avatar
6spd
now the only place where this is welded/bolted in is where it's cut out??
Old Feb 17, 2005 | 09:51 PM
JUAN J SANCHEZ's Avatar
JUAN J SANCHEZ
Your really a shameless character huh Jeff!
Old Feb 17, 2005 | 10:35 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
People worry about the weight, but they don't realize how much stronger the car is when it's done.
BTW from the looks of it you can do what another forum member did, store the top by putting it in on top of the downtubes. Just leave it facing 'forward'
Old Feb 17, 2005 | 10:39 PM
Jloshotz's Avatar
Jloshotz
Jeff,
That is one fine ZR-1 you have there. Very nice bar install too! Welded at 4 points?
Old Feb 17, 2005 | 10:42 PM
chriswtx's Avatar
chriswtx
Nice Now I really need to drag my 8 point down from up stairs and weld it in my car..Just more things to do
Old Feb 18, 2005 | 01:32 AM
Jeffvette's Avatar
Jeffvette
Yes 4 points, welded in, only where it is cut out. Here is a front angle.
Old Feb 18, 2005 | 01:55 AM
redbullapril23's Avatar
redbullapril23
did you weld in your self?
how much would it cost to get one welded in you think?
thanks alot
your friend
Sean
Old Feb 18, 2005 | 01:58 AM
redbullapril23
also cna you run 5 pts off this?
thanks alot your friend
Sean
Old Feb 18, 2005 | 02:06 AM
zelement's Avatar
zelement
Jeff,
please show your front wheel/brakes setup. Did you get the brakes from EM?
Old Feb 18, 2005 | 12:55 PM
hardlight's Avatar
hardlight
Dave Cooper at R-DRacing has some simple screw on brakets that go on the rear down tubes to secure the targa top when you let the sunshine in. I have them on my S/T Frame. Works great. Ditto all the other remarks about stiffening the chassis.
Old Feb 18, 2005 | 01:12 PM
Corvette0096's Avatar
Corvette0096
Looks like my jack is holding up good.
Old Feb 18, 2005 | 03:10 PM
Jeffvette's Avatar
Jeffvette
Did not do it myself. I had it done when the coilovers were being done with the engine work.
also can you run 5 pts off this?
Yes, you can run 5 points off of the bar.
Z, I'll try and get some pics today.
Rich, your jack is doing great. Want me to bring it home saturday morning? Also when does your tranny get back?
Old Feb 18, 2005 | 03:12 PM
redbullapril23
the rear down tubes... did they have to cut holes to get down to the frame?
and can they weld it in without...taking the rear suspension out...to get to it from the bottom?
Sean
To Rollbar strength
Old Feb 18, 2005 | 03:17 PM
VAHROOM's Avatar
VAHROOM
Default D'oh
I know what I have to try now. Thanks a lot Jeff.
Old Feb 18, 2005 | 04:47 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
If this is true, then the picture means you have somehow changed the weight distribution of the car.
Increasing torsional stiffness doesn't affect weight distribution...are you sure you are using the same jacking point?
Larry
code5coupe
Old Feb 18, 2005 | 05:16 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Larry
code5coupe
It looks like the jack is closer to the centerline of the car than the normal jacking point. Almost like it's being lifted from the rear diff ,this is what you would expect to happen.
That said, with my roll bar installed and jacking from the rear jack point, the front tire comes up VERY quickly and there is no creaking and crackling.
