22 or 24 lb injectors?
Old Feb 24, 2005 | 12:48 PM
93 ragtop's Avatar
93 ragtop
Default 22 or 24 lb injectors?
Ive been reading other post stating that the 93 vette uses 22lb injectors. I purchased a chip reader a little while back and read my factory chip. It reads 23.8 lbs. So my question is are they 22 or 24. If 22 could you direct me to some documention backing this up? Thanks.
Old Feb 24, 2005 | 12:54 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Quote:
Originally Posted by Redeasysport
I hear you are the man for chip burning. I am going to put FMS24# injectors in my pure stock 93 LT1 and have read about the WOT and possible closed loop issues. I went to you website but see no Price to burn my chip. What will it cost and what is the turnaround time? I live on the Ohio/Pa border.Any tips on how to package it so it wont get damaged?
Yeah I can help you with your chip. The 24# injectors will run too rich with your current settings and will need tweaked. Using a AFPR is just a bandaid and will not be fully taylored like a tune will be.
The cost of the chip is 250+10 dollars shipping. Payable in money order. That is 1/2 what others pay and I will redo the chips for the cost of the shipping back. So when you do your next round of mods, you can just send it back to me and I will happily redo the tune.
The best way to ship the chip is in a static free bag, and in a box. Avoid the use of plastic or other static creating material. In a box with newspapers crubled up would be fine. Be sure to include the information
The turnaround time is about 3 business days from receipt
Look forward to talking with you more. PLease let me know when you ship it out, so I can be watching for it.
Regards,
Jesse
Old Feb 24, 2005 | 03:06 PM
gbody5's Avatar
gbody5
I'm not sure what size injectors are in a 93, but if your constant was set at 23.8 I would say thay are GM 24's. What I do know is that FMS injectors are rated at a lower Fuel Pressure and thus will flow more than that what they are rated when installed in our GM cars.
My 1988 stock chip was set at 22, testing and tuning I found that ~26.25 was what I needed to work with my FMS 24 lb/hr injectors.
Old Feb 24, 2005 | 03:50 PM
Nathan Plemons's Avatar
Nathan Plemons
Stock for the LT1 is 24# I really don't know where the 22# rumor came from but it is false.
Old Feb 24, 2005 | 05:34 PM
Redeasysport
I guess what 93ragtop and I are both wondering is where can we find this info from a verifable source as there have been many answers from a lot of guys and we are not sure who to trust on this issue. Reguardless FMS 24# injectors are at a lower rated PSI so they will run richer just how much depends on this answer
Old Feb 24, 2005 | 05:58 PM
Nathan Plemons
The only thing I needed to convince me was the value for the injector constant in the ECM which is 23.8.
The ford injectors are close enough that you don't need to do any real re-tuning to use them. Ultimately though I would recommend staying with GM style injectors, they have a better spray pattern.
Old Feb 24, 2005 | 06:43 PM
93 ragtop's Avatar
93 ragtop
Nathan, Im with you on the 23.8 say we have 24lbs (approx) I was just fishing where the 22lb rumors got started and what they were based on.
To 22 or 24 lb injectors?
